ZF-6 input shaft repair kit?
Jjust saw this on bobs site: http://www.dieselsite.com/index.asp?...ROD&ProdID=588
Was wondering what yalls thoughts were?
Havent dove in yet, but the flywheel i got from Clay has the kevlar bushing in it, I know there are mixed reviews on that one and I only want to do this once.
The dang clutch / flywheel is still sitting on the garage floor, but I swear im gonna get it on there sometime soon...
Perfect,
thanks for your help fellas. I think I will order one this morning!
Will definitely take pics and post when i get after this!
Also, just found this diagram that I thought yall might enjoy: ZF6 Speed Manual Transmissions Part, Rebuild Overhaul Kits Ford Truck - Drivetrain.com
Here is a link to the same kit Bob use to sell. I have one in mine and it works great. The end of the input shaft was messed up and this fixed that too.
NV4500 Getrag 6.6 ZF 6 Speed 8.1 Input Shaft Repair Kit | eBay
KD6, I just did my clutch/flywheel a few weeks ago. After a lot of research, I didn't use the kevlar bushing from South Bend. I went with the oil-impregnated bronze bushing from Dorman. $4 from O'Reilly's. I didn't want to have another needle pilot bearing - I don't care how big they are, they're still needle bearings. My factory one was nothing but dust. My pilot shaft was a little scored, so we set the bushing in the flywheel to a spot where it was on a smooth part of the input shaft. I can dredge up the part # if you need it, or you can google 7.3 zf-6 dorman pilot bronze bushing and come up with it.
