Spring Replacement "How to"
Old Jun 9, 2010 | 11:49 AM
Splash67's Avatar
Splash67
I know that I have read a few requests for information on how to replace the springs on our trucks so when I found this tutorial I thought I would share it.
It does not appear to be nearly as daunting a task as I thought it would be.
2000 Ford Excursion V-Code Leaf Spring Installation pictures, videos, and sounds | SuperMotors.net
Sorry in advance if this is an old posting and please note that I have not tried and cannot verify that this is accurate information, nor can I be eld responsible if you have problems associated with following this tutorial.
Good Luck and have fun.
Old Jun 9, 2010 | 06:06 PM
Stewart_H's Avatar
Stewart_H
That's the one most of us link to whenever the question comes up. The only correction I make, whenever I post the link to help someone, is to tell them to disregard the step where the tutorial instructs the reader to remove the corner bumper supports to get to the front spring eye bolt on the front springs. That's wayyyyyyyy too much trouble.
The easiest way to access the front spring eye bolt is to remove the front bumper. 4 bolts and the things comes right off. It's very light too, so one person can EASILY do it.
Stewart
Old Jun 9, 2010 | 11:17 PM
EXv10's Avatar
EXv10
I thought that job was a little envolved but with disregarding some steps, it's not that bad...........it was almost a good write-up.
Old Jun 9, 2010 | 11:45 PM
ke6zmy's Avatar
ke6zmy
What if a guy wanted a little more height? Instead of 1.5" maybe 2.5" to 3". Is there a spring that would give you that much height?
Old Jun 9, 2010 | 11:59 PM
Stewart_H's Avatar
Stewart_H
Yep. X codes will give you just over 2.5". Probably closer to 2.75" depending on how tired your springs are, and if you get new X codes or used ones.
W codes will give you right at 2.5" of lift.
Stewart
Old Jun 10, 2010 | 10:46 AM
myblkex's Avatar
myblkex
Stewart
Does anyone have pictures or exact locations of these 4 bolts -- I've beeen looking around , but have not been able to figure out the 4 bolts It sure does sound a lot easier than some other peoples methods of getting to the front spring bolt ...
Old Jun 10, 2010 | 12:32 PM
Stewart_H's Avatar
Stewart_H
It's actually pretty easy to figure out which ones they are. I had no clue which ones to pull until I was actually doing my springs.
I don't have my digital camera right now, but when I get it back, I'll try to snap some quick pics for you.
Stewart
Old Mar 12, 2011 | 09:29 PM
wpnaes's Avatar
wpnaes
I've seen some Q&A on leaf spring replacement. There may be a few out there that haven't seen this picture tutorial. Mummy thread, I know... This poor Egyptian would have liked an Ex in his/her day.
Old Mar 12, 2011 | 10:06 PM
Biggone's Avatar
Biggone
Can someone help me decypher what my stock spring set up is? I can't post attachments for some reason, but my sticker inside the door states:
WB l BRK l INT TR l TP/PS l R l AXLE l TR l SPR l
137__ 4____ 4H_________ K ________9__ D/G
I am in need of replacing my springs because I have maybe 3/8" of travel on the front. This is a 2000 PSD 4X4 w/ about 240K. I am the second owner since 50K and I know everything underneath is stock. I know that I want to upgrade the fronts to a V or X code, but I would like to know what I have to start with. Any help? I found the tutorial very helpful as I will be tackling this myself. Thanks.
Old Mar 12, 2011 | 10:20 PM
wpnaes's Avatar
wpnaes
A few classic posts here: prepare to read for an hour...
https://www.ford-trucks.com/forums/6...0-springs.html
https://www.ford-trucks.com/forums/7...s-for-you.html
https://www.ford-trucks.com/forums/1...b-springs.html
Old Mar 13, 2011 | 03:00 PM
jdw1's Avatar
jdw1
You have "D"'s in the front and "G"'s in the rear.
Old Mar 13, 2011 | 03:27 PM
Biggone's Avatar
Biggone
jdw1...thanks. That is exactly what I thought and believed, but I have never seen these spring codes talked about in the treads. I believe I know what I need to do now. Thanks again.
Old Mar 13, 2011 | 05:37 PM
jdw1's Avatar
jdw1
I replaced front and rear springs on my 2000 X a year ago, as I have told others go to a heavy truck spring shop to get your new springs, the ford springs are made in Mexico and you can get springs made in USA for the same $ or less and better quality. I don't know where you are located so ford my be your only option.
Old Mar 13, 2011 | 05:57 PM
TheBestKindOfEX's Avatar
TheBestKindOfEX
Yessss, made in the USA!
Old Mar 13, 2011 | 06:25 PM
Biggone's Avatar
Biggone
I am in Montgomery, AL. I should have a place around here to go to...it will just take a little research. My biggest worry right now is what block to put in the back as I want the factory rake look. I tow a 31' Jayco Eagle at about 9000 lbs loaded. I appreciate the advice.
