1978 - 1996 Big Bronco
She just quit running
Old Jun 9, 2010 | 07:57 AM
Johnny Yarbrough's Avatar
Johnny Yarbrough
Driving home the other day my 1990 Bronco just died. No spark from the coil so I changed it. Looked in the old Chilton repair book it mentions a dist. module . Could it need to be changed and do you need a special tool to change it out. If so where would you get such a tool. Or is there something else I need to check before tearing into the dist. The Bronco ran great before this happened , it just died.
Old Jun 9, 2010 | 08:14 AM
Encho's Avatar
Encho
The Southernmost Mod
Always go for the easy jobs first. Check all the fuses (specially the one that belongs to the fuel pump), then get a Code reader and see what it tells you.
Old Jun 9, 2010 | 09:10 AM
Johnny Yarbrough
You can hear the fuel pump come on when you turn the key on . It was replaced less than a year ago .
Old Jun 9, 2010 | 09:49 AM
Kemicalburns's Avatar
Kemicalburns
pull codes
does the motor turn over but not fire? after changing the coil did you still not have spark?
your dizzy may have failed or the TFI module which is mounted to the side of the dizzy failed.
Old Jun 9, 2010 | 10:10 AM
g_k50's Avatar
g_k50
Replace Distributor, save yourself alot of troubleshooting, been down that path with my 1990 Bronco. Pictures have been posted.
Tool to replace ICM on Dist is a deep well thin sided socket (5.5 mm). I got one at Ace Hardware, actually I had to buy a set.
There's a stator, deep in the distributor as well as a PIP sensor, I replaced all the parts in the Dist and the ICM too. Then I did the fuel pump.
Old Jun 9, 2010 | 10:45 AM
andym's Avatar
andym
Diagnose first, replace parts second. Much cheaper this way.
Start with pulling the codes, and then tell us what the truck is doing.
Old Jun 9, 2010 | 01:19 PM
greystreak92's Avatar
greystreak92
Ditto, ALWAYS diagnose first... replacing parts arbitrarily just wastes time and money.
Old Jun 9, 2010 | 03:21 PM
g_k50's Avatar
g_k50
Did I miss where someone suggested I rebuild the distributor in my case?
https://www.ford-trucks.com/forums/7...-no-spark.html
Nope didn't miss it, it wasn't there.
Took me 6 days of troubleshooting to figure it out. No help from this site.
Old Jun 9, 2010 | 06:10 PM
greystreak92
Then why bother asking? No one suggested rebuilding the dizzy because it didn't need a complete rebuild. It needed a new PIP sensor but most folks don't or won't take the time or have the patience to properly disassemble the distributor and replace just the sensor which is a ludicrous notion. Spending the money on a whole distributor as opposed to a Profile Ignition Pickup sensor just makes no sense. Your symptoms in the thread referenced above would have been gotten to but there is no point in attempting a response when the methods applied (and posted) are contrary to the diagnostic process for a dead PIP sensor.
Old Jun 9, 2010 | 07:05 PM
g_k50's Avatar
g_k50
I'm not assuming that the OP has the skills to do a complete rebuild. It's a job requiring a vice, punches, hammers, and some level of training and experience. Not for the sidewalk, driveway mechanic.
79 sb150
23
Jan 11, 2006 11:13 AM
Zoomie331r
Electrical Systems/Wiring
Jul 14, 2004 06:29 AM
Bearee
17
Mar 21, 2004 06:29 PM
diggum
Jan 28, 2003 07:20 PM
