Straight Pipe?
Old Jun 9, 2010 | 06:07 AM
mcantar18c's Avatar
mcantar18c
Straight Pipe?
Well she ain't sold yet and I haven't gotten much interest recently, and I've been dying to do some wrenchin, and my neighbor is pissing me off and hates the "noise" my truck makes... so I'm thinkin it's time to straight pipe it .
Currently it's 4" turbo-back, cat but no muffler, dumps in front of the rear wheel right at the edge of the wheel well.
I've straight piped vehicles in the past but they were all gas burners, so I've got a couple questions. I've been searching around on google and have come up with some conflicting info.
1. First off, is this even ok to do? I've heard that a 4" straight pipe won't give me enough backpressure, but then I've also heard that the turbo creates enough bp that in theory I could run with just the downpipe.
2. Logic (or my version of it) says that a more free-flowing exhaust will lower my EGTs, produce thicker smoke without the cat, the turbo will spool quicker, and should result in a little more power and better acceleration off the line... not directly, but the quicker spool time will. But then I've read that a straight pipe on a 7.3 will obviously sound better, but that it'll give you no actual benefits like EGTs and whatnot... but that doesn't make sense to me. So what's your guys' imput on this?
3. For the cat delete, which is really all I'm doing, I see 2 options: 1) Get a 4" pipe and swap it in, so it'll just be one long stretch of 4" pipe, or 2) Use a larger piece of pipe, maybe 5" or 6", to act as sort of a resonator. Thoughts?
I know I could always just gut the cat, but I'd like to keep it intact for when emissions time rolls around.
Thanks!
Old Jun 9, 2010 | 07:11 AM
mcantar18c's Avatar
mcantar18c
Oh yeah, I've got an exhaust brake too, so that should be adding a little more backpressure.
Old Jun 9, 2010 | 09:47 AM
glasseater's Avatar
glasseater
the turbo creates enough back pressure, don't be worried about that
free-flowing exhaust will lower EGTs, raise boost a tad, only increase visible smoke because of the lack of a cat, and will enhance spool up... you may notice a tiny power difference but that can be attributed to the quicker spool up and thus more torque which means more power early in the rpm band
just use the same size pipe you have, whether its 4" or 3.5" or whatever, try to keep the size the same... if you make the size get larger then smaller then larger again, or vice versa, it'll just limit flow due to turbulence
Thanks!
also, some guys like to cut the cat in half, put a 3.5 or 4" pipe in the center and weld it back together, looks stock when its really not
Old Jun 9, 2010 | 11:29 PM
mcantar18c's Avatar
mcantar18c
Awesome, thanks for the info.
And yeah I've seen that done before, and that'll pass a visual inspection, but where I live (Denver) they also do a particulate test where they shine a light through your exhaust and see how much of the light passes through, so I think without a cat I'd fail that one.
ernesteugene
49
Aug 12, 2015 11:46 AM
Ronin 5729
6.4L Power Stroke Diesel
28
Dec 11, 2011 05:31 PM
BlueOvalBud
13
Dec 26, 2010 05:47 PM
spdmpo
Nov 26, 2010 08:52 AM
ChronGen
Exhaust Systems
17
Nov 8, 2005 08:30 AM
