need help again
Old Jun 8, 2010 | 10:11 PM
topdrive's Avatar
topdrive
Cool need help again
hey guys once again my truck is acting up it has a noticable miss and lack of power pulled the codes and came up with p0275 cylinder 5 injector circuit contribution/balance fault any ideas what could be causing this i have never had this code before
Old Jun 8, 2010 | 10:35 PM
npccpartsman's Avatar
npccpartsman
Most likely it's an injector. That code means that cylinder #5 isn't keeping up with the output of the other 7 cylinders. It could also mean other things but they are much more major. I just did that one today myself. Passenger side, 3rd one back and fun to do.
Old Jun 9, 2010 | 06:53 AM
topdrive's Avatar
topdrive
thats not what i wanted to hear i had that whole side changed last summer i wonder why it only lasted 40000km this truck is becoming very exspenive to keep i guess i will talk to the dealer that did the work and see if they will warranty there work thanx for now
Old Jun 9, 2010 | 07:10 AM
bismic's Avatar
bismic
Do you monitor the fuel pressure?
Old Jun 9, 2010 | 08:28 AM
topdrive's Avatar
topdrive
i checked my fuel pressure a couple of months ago at wot it held steady at 50psi the fuel filters only have 3000km on it as well as the the oil i use 5w40 synthetic and have always used fuel additve in every tank
Old Jun 9, 2010 | 08:30 AM
gearloose1's Avatar
gearloose1
Think what bismc is saying is you need to be constantly monitoring it, not just occasional checks.
I am a tad uncomfortable --- a weak cylinder can be caused by many things, including bad valves, rings, piston, head gasket, etc.
Old Jun 9, 2010 | 08:41 AM
adamtheman16's Avatar
adamtheman16
As well as broken rocker arm components...
Old Jun 9, 2010 | 08:46 AM
topdrive's Avatar
topdrive
now you guys are starting to scare me it better not be a head gasket theres only 50000km on brand new heads and arp studs i would think if anything was broken i would be able to hear it the truck still idles good its when you step on the go pedal it starts popping and farting its an obvious miss as far as i can tell
Old Jun 9, 2010 | 08:52 AM
gearloose1's Avatar
gearloose1
When you do that many "fixes" to it, sometimes, you tread on the "ain't broke... " rule.
There is something about a factory assembled engine that few field repair shops can duplicate: cleanness, consistency, qc, testing, etc.
The very best custom blueprinting shops that work with top grade new (or seasoned) parts that are carefully checked / tested for flaws, can do better than a factory.
But that is not where most engine work ends up.
http://en.wikipedia.org/wiki/Engine_tuning#Blueprinting
Old Jun 11, 2010 | 09:10 AM
topdrive's Avatar
topdrive
finally got an update from my dealer they are telling me i have a severe case of stiction i can understand that but how could i get it that bad on an injector that only has 40000km on it and because it is not an injector problem they will not warranty there work they told me injectors only have a 20000km warranty on them and the only way to fix it is to replace it I dont get it i have been running syntetic oil and changing it every 7500km since i put these injectors in what else can you do to stop this from happening again
Old Jun 11, 2010 | 09:18 AM
69cj's Avatar
69cj
Try adding one ounce of ashless two stroke oil per one gallon of fuel. Some on this site do that for the extra lubrication. Since you are apparently out or warranty it can't hurt and may very well help you.
Old Jun 11, 2010 | 09:37 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
You could give this stuff a try: REV-X Oil Additive | Diesel Fuel Additive | High Performance Oil
