code questions
Old Jun 8, 2010 | 10:04 PM
alfred foulds's Avatar
alfred foulds
code questions
hello everybody
im new to the site. i just bought a 2000 ford 7.3 crew cab. but i had a couple of isues. found out the hard way the truck doesn t like water.lol
but it sat a awhile and the batteries died. the question is right after it broke down it didn t have any codes in the conputer. i drained the water out .and charged the batteries and now i have these codes.
p0231-fuel punp relay driver circuit failure
p0562-low voltage
p1690-wastegate control valve nalfunction
could low voltage (dead batts) cranking cause these codes. the truck is running fine. i think, its still new.
i was losing power and blowing white snoke. then it would run fine. and slowly got worse to the point it didn t stop. got it towed.
thanks
john
Old Jun 9, 2010 | 12:37 AM
Visseroth's Avatar
Visseroth
First off!! Welcome to the forum!!!!
Second, yes, low voltage code can and usually is caused by low batteries and/or an alternator that is not charging like it should.
I would clear the codes and see if they come back, give it about 3 runs and check for the codes again.
Did you ever figure out why your truck was blowing white smoke?
acm05fsu
1997 - 2003 F150
Dec 26, 2019 02:24 PM
tracyclifton
May 28, 2014 02:29 PM
JCark
Nov 27, 2012 07:34 AM
Sullid01
Oct 1, 2011 02:10 PM
richrob
Jul 29, 2011 12:02 PM
