Sponsored by: Auxito
adding payload capacity
Old Jun 8, 2010 | 08:45 PM
97XLT4X4's Avatar
97XLT4X4
this may be dumb but we do landscaping, and after hauling 4 yards of mulch in the bed/trailer, i feel like a better set up for hauling is better, can u do any add-a-leaf on these 1/2 ton f150's?
any other alternatives?
Old Jun 8, 2010 | 08:48 PM
steve(ill)'s Avatar
steve(ill)
you can add a leaf or add air bag or air shock to increase load capacity. The max capacity is determined by the axle rating and the motor size.. have you got a 4.2 with small rear end, or a 5.4 V8 with the 9.75 axle ?/ makes a difference.
Old Jun 8, 2010 | 08:51 PM
97XLT4X4's Avatar
97XLT4X4
we have the 4.6, i'm not sure how to check the rear end,
rpo codes?
Old Jun 8, 2010 | 11:44 PM
Tex1986's Avatar
Tex1986
there should be a tag with the axle code on it. Post it and we can tell you what it means
Old Jun 9, 2010 | 01:01 PM
galaxie641's Avatar
galaxie641
4.6L has the 8.8 rear.
Old Jun 12, 2010 | 11:55 PM
cogden's Avatar
cogden
8.8's are not too tolerant to overloading, the bearings used in those rear ends are very small and they will fail if loaded too far beyond what they are rated to. It would be wise to install a 9.75 rear as part of your payload upgrade. Expect slightly lower performance and gas mileage though because the larger differential will provide more frictional losses in your driveline.
waystro
17
Apr 1, 2015 09:20 PM
xmontex4
Aug 18, 2014 10:41 PM
bleedford
2009 - 2014 F150
Mar 13, 2012 11:31 PM
68-F250-4x4
15
Mar 10, 2008 09:16 PM
lpbaca
Sep 8, 2005 06:49 PM
