Sponsored by: Real Truck
2000 5.4 Starting issue.
Old Jun 8, 2010 | 04:41 AM
GIL4X4's Avatar
GIL4X4
For some reason on a cold start when I go to crank the ignition over the starter clicks like the battery is dead, but as I hold it for about 15 seconds it starts to crank and then fires up. I am getting 13.6 at the battery and I think a bad ground would probably not get fixed by holding the key in the start position. It seems like an issue with the starter which has given me problems in the past, or possibly the terminals. My truck is a 2000 5.4 E4OD 4x4, anyone experience something similar or have any ideas what might be going on?
Old Jun 8, 2010 | 05:13 AM
mrford60's Avatar
mrford60
clean all the terminals on the starter and i would check the grounds also. make sure the battery cable to the starter is not cut or damaged, it sounds like you are not getting enough voltage to the starter.
DougNC
Modular V8 (4.6L, 5.4L)
Jan 23, 2015 08:49 AM
Solar07
Jul 10, 2012 06:13 PM
rkul80
May 31, 2011 10:41 PM
dpm1057
May 8, 2007 07:19 PM
HUNTER10
Nov 25, 2006 08:30 PM
