Battery problem/question
Old Jan 21, 2015 | 02:00 PM
DougNC's Avatar
DougNC
'02 F250 XLT with 5.4L. For several months my battery would intermittently crank the truck but not start it. Sometimes, it would start, almost get 1,000 RPMs, then die. Then I'd run the battery dead trying to get it started. I recently took the truck to Advance, where the battery tested bad with only 490 amps. A new battery has apparently solved the problem.
Can the battery have enough volts to crank the starter normally but not enough amps to operate various sensors/systems so the truck will start?
Old Jan 23, 2015 | 08:49 AM
speakerfritz's Avatar
speakerfritz
As the battery begins to provide starting current, voltage begins to drop. so if you have 1000CCA's the start process will last longer than a batttery with 800CCA's before the battery voltage begins to drop.
the longer the start process takes...the deeper your battery is discharged...the shorter the battery life.
as the engine starts to spin, the alternator begins to add amps to the circut and helps the spin up process.
if you find short battery life is at play here...have your alternator tested at low RPMs.
goldieWilson
Mar 22, 2015 07:42 PM
SUPERDUTY OUTLAW
16
Jun 16, 2013 01:14 PM
aviatorcal
Feb 23, 2013 09:16 AM
79F-1504x4
53
Mar 3, 2011 01:53 PM
97 RED PSD
1997 - 2003 F150
Dec 21, 2005 12:01 AM
