speedo stoped working wright
Old Jun 7, 2010 | 09:44 PM
jchinlee's Avatar
jchinlee
1996 ford ranger 3 L speedometer reads 25 mph with key on 0 with key off shows speed + 25 mph when backing up help ????<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Jun 8, 2010 | 12:14 AM
bankshot's Avatar
bankshot
Maybe Speed Sensor on the rear differential. Or the computer needs reprogramming.
I thing you meant right, right?
Old Jun 8, 2010 | 01:41 AM
jchinlee's Avatar
jchinlee
speedo
yes it was right .how do you reprogram the computer
Old Jun 8, 2010 | 07:37 AM
powersmoked's Avatar
powersmoked
Originally Posted by jchinlee
1996 ford ranger 3 L speedometer reads 25 mph with key on 0 with key off shows speed + 25 mph when backing up help ????fficeffice" /><o>></o>>
change the speed sensor in the top of the diferentil. you remove one bolt i think it is a 10mm pop out the senosr disconnect the wire. CLEAN THE AREA WELL. PUT SOME OIL ON THE ORING OF THE NEW SENSOR AND INSTALL. takes about 10 minutes. I backed mine up on car ramps but it is not necessary
if that does not work check 2 harnesses under the truck by the fuel filter
Old Jun 8, 2010 | 07:59 PM
jchinlee's Avatar
jchinlee
changed Speed Sensor on tailshaft of trans no help
Old Jun 8, 2010 | 08:05 PM
powersmoked
YIKES
I DON'T KNOW WHAT ELSE TO SA............YIKES
Old Jun 8, 2010 | 08:14 PM
ford-speed's Avatar
ford-speed
that is a very common problem to those speedometers. you must remove the speedometer from the cluster and re solder the circuit board. if you have a magnifying glass you may be able to see the bad solder joint.
Old Jun 12, 2010 | 07:15 PM
jchinlee's Avatar
jchinlee
96 ranger speeometer
removed the speedometer from the cluster and find no bad solder joints on the circuit board. have checked two speedo heads with a magnifying glass <!-- / message -->
