Sponsored by: Real Truck
DEF - where ??
Old Jun 8, 2010 | 12:27 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by GUNNERDOG
You have to be joking... i can understand a check engine light or something being triggered by low DEF, but capping speed to 4mph? That IS basically stranded. Does Ford do this too?
I don't know if it's 4mph or not, but yes.
A series of warning messages begin to be displayed when there's around 1000 miles worth of fluid remaining in the DEF tank. There's really no excuse for allowing it to run out.
I'm sure the speed cap wasn't the idea of any of the manufacturers, but rather a mandate from the government.
Old Jun 8, 2010 | 12:31 PM
GUNNERDOG's Avatar
GUNNERDOG
Originally Posted by vloney
It goes to idle only. And it does give you plenty of warning beforehand.
until your sensor starts acting up... how many threads have there been about quirky gas gauges? At least I can still drive if my gas gauge is reading empty...
Old Jun 8, 2010 | 12:39 PM
vloney's Avatar
vloney
The DEF gauge is separate from the fuel level gauge.
Old Jun 8, 2010 | 02:10 PM
GUNNERDOG's Avatar
GUNNERDOG
Yes, but my point was that it will be no more dependible than the fuel gauge. Sorry, Im done ranting.
and to the OP:
http://www.afdc.energy.gov/afdc/locator/def/
Old Jun 8, 2010 | 04:07 PM
redford's Avatar
redford
How long before someone markets a tailpipe fluid delete kit?
Old Jun 8, 2010 | 04:09 PM
senix's Avatar
senix
I have one already...it is a drill and your choice of bits.
Old Jun 8, 2010 | 04:18 PM
radzer0's Avatar
radzer0
Originally Posted by senix
According to the chief engineer, Chris Brewer, the interval for most should be around 7500 miles, or at every oil change.
Im at 2900 miles and according to the dash thing for the past couple hundred miles ive been "below half a tank"
Old Jun 8, 2010 | 04:52 PM
vloney's Avatar
vloney
Its not made like the fuel gauges of the past. It is designed to show you that message at that point. When you get within a certain distance, the message will change. It will give you caution messages at closer intervals the more you drive. When you run out, it will give you 1 reset for emergency drive to get a refill. Then you'll go to idle only. You'll have ample warning before you get to that point.
Old Jun 8, 2010 | 06:50 PM
my996duc1's Avatar
my996duc1
where do I see how much DEF I have in the tank ??
in what area of the dash ?
Old Jun 8, 2010 | 07:36 PM
06silvercrew's Avatar
06silvercrew
Nope! Its just like oil and fuel, it gets consumed with driving. I think they'll help with the first fill up, but after that, you're on your own. GM does the same thing, and Dodge has some contraption called a NOX trap.
Yeah I could be wrong, as us GM guys are behind the times as far as getting any 2011's. An instructor told me this in a recent duramax class so I was just going off that. I will be in his class again thurs and friday so Im gonna pick his brain on the topic.
EpicCowlick
6.7L Power Stroke Diesel
47
Aug 30, 2016 12:06 PM
bracyder
Sep 1, 2014 08:02 PM
bit_bucket
46
Nov 21, 2013 02:32 PM
Champ198
37
Aug 13, 2011 12:04 PM
Tacswa3
Feb 26, 2011 08:28 AM
