I am getting no spark and have replaced the Cap,roter,coil ingnition module crankshaft sensor,wires and plugs.
It is a duraspark 3 system.What else can I try?
Thanks,
Ken
>else can I try?
> Thanks,
> Ken
After replacing all that you might check your pickup coil in your distributor. You will have to pull the dstributor to access it but if you mark your cap and housing shaft you wont have to re time it. In the earlier models usually the duraspark ignition module located on the inner fender well is the culprit. I keep a spare. Good luck
I was reading and found out he might not have a pickup coil in his distributor. The computer fires his module (duraspark III) instead of the distributor.
