6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
F250 does 160mph..
Old Jul 12, 2010 | 11:05 PM
  #31
LaxPlaya21's Avatar
LaxPlaya21
Originally Posted by Crazy001
At 4,125 RPMs the engine would need to be belting out 833 ft-lbs of torque, assuming Ian's calculator is correct.
So has anyone here seen a PSD, however modded, make that much power above 4,100 RPMs?
The power can be made easy enough, but at a lower RPM which would require a much lower ratio rear end gear to get up to 160 MPH. A Spartan-ized 6.4L truck running the 310 tune with a 2.73:1 ratio rear end would hit 160 at 3,100 RPMs.
I personally don't think that is the route to go to hit 160. There are a few things that need to be addressed first. First use a F250 with the short cab and the short bed. The huge issue that needs to be dealt with is aerodynamics. The truck definitely needs a front and rear spoiler to push this thing to the floor and help cut through the air. Drop that truck to the floor and add a solid suspension. Then I would lose the heavy stock wheels for lighter ones and add some racing tires. Then you need to lighten the internals to allow it to rev out more. I think if the truck could reach 6000rpm and still be making power it will hit some seriously fast speeds. And I think this could be accomplished! I also think the gearing wouldn't be less than 3.73... at least not by much.
Old Jul 13, 2010 | 06:55 AM
  #32
pony puller's Avatar
pony puller
but lets all remember one thing, speed kills. as a emt i have been to many of accidents and no one wins, the family pays in the long run. the only place this is safe is on a track,not the road. 60 or 160 u hit some one in a rig this big it's all over. we have are rigs to work and enjoy, and make money. lets all be safe. sorry for rant here, but just my .02
Old Jul 13, 2010 | 08:02 AM
  #33
Tom's Avatar
Tom
Very good points about aerodynamics. I was simply thinking of putting the power to the ground at the right RPM.
And I'm no engineer but doubling the peak power RPM while going over redline by over 50% simply doesn't seem possible. Those heavy rotating components don't like going fast. I remember reading about a 6.0L user who destroyed his heavily modded engine at well less than 6,000 RPMs. On edit: Look HERE
You wouldn't loose anything by really tall gears. Producing that much more power than stock you'd never see any real disadvantage. Plus you'd be able to keep the engine mostly stock!
Old Jul 13, 2010 | 04:11 PM
  #34
Jerry-Rigged 6.0's Avatar
Jerry-Rigged 6.0
Hey dont short-change yourself, that was .04 cents, I counted I do agree, a feat like this should be conducted as safely as possible, roll cage, 5pt harness, helmet, etc. etc. , and also should probably take place at the salt flats or vacant runway. (put a chute on the back also)...If I had the money this would be all mine, but I can barely afford to replace my 5r110 with a used one so I guess Ill have to stand by and wait for some results....Its fun to bicker about tho, thats for sure
Old Jul 13, 2010 | 04:14 PM
  #35
Jerry-Rigged 6.0
I think what he was talking about is modifying the internals of the engine so they are capable of 6000rpm, which I am sure is possible but expensive....but hey, Im just a ...
Old Jul 15, 2010 | 01:01 AM
  #36
BAD351W's Avatar
BAD351W
I hit a GPS indicated 103.7 in my 96F250/351 with 3.55's. With 33/12.50s. I dont see why one of these trucks couldnt hit stupid speeds.
Old Jul 15, 2010 | 10:37 AM
  #37
LaxPlaya21's Avatar
LaxPlaya21
I understand why everyone thinks that but the difference between 100 and 160 is tremendous!
Old Jul 15, 2010 | 11:03 AM
  #38
LaxPlaya21's Avatar
LaxPlaya21
About 60% of the power required to cruise at highway speeds is taken up overcoming air drag, and this increases very quickly at high speed.
Old Jul 15, 2010 | 11:10 AM
  #39
Lead Head's Avatar
Lead Head
For every time that your speed doubles, your wind resistance increases by a factor of 4.
Old Jul 15, 2010 | 05:47 PM
  #40
LaxPlaya21's Avatar
LaxPlaya21
I know how difficult it is for a motorcycle to reach speeds of 170+ and they have all the power and rpm in the world. They just can't overcome wind resistance. Also, our trucks let soo much air underneath them... That translates into lift!
Old Jul 16, 2010 | 11:02 AM
  #41
jlrFordFan's Avatar
jlrFordFan
calculations are easy, formulae simple
Completing Leadhead's thought. Wind resistance or drag is a function of the fluid (air in this case) and proportional to the square of the velocity however...We must remember that to go fast we are overcoming drag, a force, but we overcome that force with Power which is force times velocity. Thereby bringing in another multiplication by velocity. Therefore it is concluded Power must increase proportionaly to the velocity cubed. Its too late to do the math but I'll put together the calculations. You guys give me some feedback to put in my equations. I am looking for some guesses on: 1)the coeficient of drag for an F250 (I think .7 is reasonable) and 2) how much power is being used by the engine to overcome drag at 55mph (LaxPlaya21 says 60%, 60% of how many HP?? 200??). I don't care about the rest of the power being used to go 55 ( ie. drive train losses, inertial losses, heat, etc. Just the portion overcoming drag. Give me a few responses and a few days to get back in the country and I'll give you some power comparisons to go 55, 100, 130 and 160
Old Jul 16, 2010 | 11:08 AM
  #42
jlrFordFan's Avatar
jlrFordFan
not lift, drag
Lax, the more air going under the truck the less lift, sorry. Lift doesn't come from underneath, lift is a function of the airspeed going over the truck. More air over and less underneath creates lift. the more air under decreases the speed relative difference in the velocity between the air going over and thereby reduces lift. However your thinking is correct in the speed reduction by increasing drag, for the more air under = more laminar flow broken up into turbulent by those nice 20in tires, the exhaust and all the other components down there creating lots of drag increasing the Cd (drag coefficient).
Old Jul 16, 2010 | 11:24 AM
  #43
MonaVie1's Avatar
MonaVie1
160 in stock trim sounds like BS to me.
Old Jul 16, 2010 | 11:36 AM
  #44
LaxPlaya21's Avatar
LaxPlaya21
You are 100% right.
Old Jul 17, 2010 | 12:31 PM
  #45
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Originally Posted by Brandon D
If I was a little younger and a little dumber I would put this to rest and give it a try and shoot the video while doing it, haha. I've had my bike up to 180mph and I agree that is crazy fast and the thought of getting close to that in an F350 is insanity. However, I will stand by my original statement and I do believe 160mph is possible on a good stretch of highway. Any takers?
I bet with a tuned 6.4 it could do it.
