weird problem
Old Feb 4, 2003 | 06:44 PM
lawless's Avatar
lawless
weird problem
I have a 1989 e150 that makes weird noise. When the engine is warm and i start it. It makes a noise that sounds like a backfire in the exhaust manifold. Has anyone had this problem before or know what it is. thanks for the help.
Old Feb 4, 2003 | 07:41 PM
black874x4's Avatar
black874x4
weird problem
When does the noise occur? My 302 backfires on acceleration through the intake.
Old Feb 4, 2003 | 10:42 PM
samhihn's Avatar
samhihn
weird problem
It may be a backfire. This would only happen if there are fuel vapors in the manifold . Ignition could be caused by hot carbon or poor valve timing. hmmmmm it's an '89. I'm guessing close to 200k miles. Timing chain maybe? How's it running otherwise?
Old Feb 5, 2003 | 07:50 AM
lawless's Avatar
lawless
weird problem
It has a 302 and the noise occurs about 3 or 4 seconds after i start the engine. it usually occurs when the engine is at operating temperature. It has about 170k on it and other then this it runs fine. Also another clue might be that the exhaust manifold has a crack in it. the noise sound like a series of muffled pops coming from the exhaust manifold. i thought it might have something to do with the air injection system but i'm not sure.
Old Feb 5, 2003 | 06:52 PM
samhihn's Avatar
samhihn
weird problem
I"m thinking that with a crack in the manifold you may just be hearing exhaust pop until the temperature makes the metal move again. I think the air pump feeds the air into the exhaust further back in the system if I remember right. Hey ......if it's runnin' good, what the heck! Just keep an eye out for another manifold for a van. Best of luck..........
dmen
Nov 28, 2011 12:52 PM
KoolAidMan888
Oct 12, 2010 04:46 PM
STILLEN/EXEPIDITION
Sep 8, 2008 10:23 PM
shurbs2004
May 18, 2007 04:14 PM
79rancher_boy
Sep 20, 2004 11:36 AM
