F350 Weight
Old Jun 5, 2010 | 09:39 PM
Fuelhog 5212's Avatar
Fuelhog 5212
F350 Weight
I have a '93 crew cab with 8' bed. For curiosity sake I went over the scales today with it. It read roughly 2000 kg on the front axle and 1200 on the rear. That's a basic mt weight of 7000 lbs. Sounds a bit wacky to me..I was thinking about 5 or 6. Just wondered if anyone has weighed theirs and also if someone might know the gvw as I cannot find a tag on it?
Old Jun 5, 2010 | 09:42 PM
joe f350's Avatar
joe f350
on my title is says i way 6105 pounds with my lift and tires lol idk y
Old Jun 5, 2010 | 09:44 PM
jmmartin's Avatar
jmmartin
i ran mine over the scales at work a couple years ago... f250 xtcab 8' 7020Lbs
Old Jun 5, 2010 | 10:15 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
7k with stock bed sounds about right to me too.
add extra springs and a bed with lift etc,then you can expect closer to 8k.
the scales you used sound accurate.forget 5/6 k weight ratings with the HD diesel trucks.
remember we have thicker frames,heavier axles,brakes,and our diesel's with oil is about 1k alone.
forget gmc's claim of "professional grade" it's been ford all along.
Old Jun 5, 2010 | 11:29 PM
Fuelhog 5212
Yeah, I was a bit surprised, not thinking quite that heavy but scales don't tend to lie. I guess I shouldnt complain about 17mpg or so..
Old Jun 6, 2010 | 12:21 AM
oreocreaming's Avatar
oreocreaming
90 crew cab, longbed 4x4 i rang in at 8860 sunday. thats with 100 gallons (800 lbs) in the bed.
Old Jun 6, 2010 | 12:43 AM
powerstroker100's Avatar
powerstroker100
does it say on the door sticker how much our trucks weigh?
Old Jun 6, 2010 | 12:47 AM
oreocreaming
should only say gvw on the door. meaning your max allowed axle weight.
Old Jun 6, 2010 | 01:22 AM
powerstroker100
oh okay, so is gross vehicle weight rating the same as what the truck is rated for payload capabilities?
Old Jun 6, 2010 | 01:43 AM
oreocreaming
yes, tires permitted that is...
Old Jun 6, 2010 | 02:23 AM
peruses's Avatar
peruses
umm
dry weight of the vehicle+alowable payload=gvwr
don't forget you and your pasengers are part of the payload
thus if my f250 weighs 7k and gvwr is 8800 then legaly I can cary 800 pounds of pasengers and 1000 cargo or tounge weight
Old Jun 6, 2010 | 06:43 AM
JoeyB94's Avatar
JoeyB94
i run mine over the scales at the scrap yard and the local quarry alll the time and it weighs 6,200lbs empty. 92 F350 na regular cab with the zf5 knee knocker in it.
Old Jun 7, 2010 | 05:10 AM
91dirtydiesel's Avatar
91dirtydiesel
mine on the scale is 6900lbs
Old Jun 7, 2010 | 09:39 AM
Vacationtime247's Avatar
Vacationtime247
1989 F-350 Crew Cab 7.3 idi / 5 spd Dually @7,000 lbs x 2 different scales. Recycled some used metal 7k and through out some trash at the dump 7k. Your numbers are correct and it's confirmed, your truck is fat.
VT247
Old Jun 7, 2010 | 03:44 PM
catbird7's Avatar
catbird7
1989 F-350 Reg Cab 7.3 idi / 5 spd 4x4 weighs 6800lbs.
