4R70W Transmission Fluid change question
Hey all,
So lately my transmission has been slipping ( atleast i think its the tranny ) whenever i come to a stop and try to go. If i apply the brakes hard or even just apply normal pressure to come to a stop then when i go to take off again its like its in neutral then catches itself and starts going again. this mainly happens when i brake harder then normal but has been becoming more and more constant even under normal. My fluid levels seem normal, after a drive i go in park and check the dipstick and its in the full range. I was considering doing a fluid change ( draining the pan and TC ) and refilling everything as well as a new filter. My question is ive read a few times that on these older trucks after doing a fluid change on the trans and putting new stuff in it the trans can stop working like the old fluid was basically holding everything together. Ive only had this truck for about 8 months now and done alot of repairs on it, trans and diff are the only two things i have yet to do a change on. Is it possible or how high is the chance of after changing the fluid of the trans not working anymore or becoming worse then it is now? Once it kicks back in after taking off it shifts fine and downshifts fine. Does this sound like a slipping issue or another possible issue like maybe the differential slipping? Im no expert but im learning at a fast pace as i go.
( Also the fluid to change the trans would be Mercon V right? )
Thanks for any help
Transmission - 4R70W 4 speed auto + overdrive
8.8" 3.08:1 Open Differential
1995 F150 5.0 302 XLT
203k Miles
Thanks for any help
203k Miles
What DOES happen is that transmissions are usually ignored. When something goes wrong because the fluid was never changed things happen like the trans goes to neutral at stops. Then the fluid is changed and the trans dies. What they don't realize is that the trans was damaged by not changing the fluid. It was going to die if the old fluid stayed in there. The new fluid didn't cause the failure. It also wasn't able to prevent the failure.
A differential can only slip one time. The only way it can slip is when teeth are broken off the gears. Once they break off they don't put themselves back on.
Right.
No, it is not a four speed plus overdrive. It has four total ratios, and one of those is overdrive.
Is the engine running when your checking it? If not, then the level on the dipstick is meaningless.
Old fluid holding everything together is a myth. It can't happen.
I'm guessing it is likely it will be worse after changing the fluid. I also predict it is going to get worse if you don't change the fluid. The only way this isn't going to be terminal is if the fluid level it quite a bit low.
Right.
Right.
Thanks
What I was getting at is that your transmission has a mechanical failure inside. Whether or not you change the fluid this transmission isn't going to last a lot longer. At this point I think changing the fluid is a waste of money.
medic503
07-12-2013 11:52 AM
