dtc code question
Old Jun 5, 2010 | 08:30 PM
fixitman1310's Avatar
fixitman1310
dtc code question
hey guys i did a cylinder contribution test on my 96 f250 powerstroke.
i used the auto enginuity computer. i got the code p0269 cyl 3 bal default.
i also did the buzz test and all 8 injectors buzzed. the milage is 144,000.
has new epr, fuel pump, filter, oil change, idm, under valve cover harness
on both sides, new glow plugs. truck starts up easy but runs rough.
does this sound like bad injector or wiring. any help appreciated.
thanks alot
steve n.carolina
Old Jun 5, 2010 | 08:55 PM
F350-6's Avatar
F350-6
Go to the live data tab and watch your rotational velocity numbers. You can also watch ICP psi and ICP % (IPR).
How rough is the idle? Have you tried unplugging the ICP sensor at idle?
Old Jun 5, 2010 | 11:46 PM
fordpride's Avatar
fordpride
what CPS do you have in it.
Old Jun 6, 2010 | 06:36 AM
fixitman1310
i have a cps from ford. i replaced it a few months back because the motor was
cutting off on me for no reason. i have the proper voltage at the icp. i unplugged
the icp, check eng light came on. the motor bogged down for about a second
and smoothed out a little. the engine shakes and runs rough when i start it.
it starts right up without letting the glow plugs cycle. my icp pressure was 570 psi
at 650 rpm. i will hook up puter and check icp % and rot vel thanx guys
Old Jun 6, 2010 | 07:44 AM
Talyn's Avatar
Talyn
What other codes did you get when you checked your DCT's.
Post the codes.
CCT needs to be run with the engine at full operating temperature. as in. 190F Degree oil.
Old Jun 6, 2010 | 10:13 AM
fixitman1310
hey guys i checked each injector reading from the idm harness plug. i read 3.1 ohms
from each injector. i am only reading code p0269 3 cyl bal fault injector. again i did
a buzz test. all eight injectors buzzed. i did get p1111 pass code. no other dtc's.
i need a mega ohm meter to check shorted circuits. any other ideas. oh my glow plug
wire from starter relay to glow plug relay gets hot enough to burn you.
what else can i do. could injector 3 be bad or loose screws or something
thanx guys
Lawrence Lal
Sep 21, 2016 08:53 PM
jstihl
56
Jun 10, 2016 11:22 PM
bobg206
Oct 1, 2015 07:20 AM
kurboman
Oct 26, 2014 08:33 PM
muddyforeman
28
Nov 1, 2009 06:37 PM
