Groans when turning
Old Jun 5, 2010 | 06:48 PM
Medic 66's Avatar
Medic 66
Groans when turning
When I turn left or right sharp or not so sharp I have a terrible groaning noise that is louder than my engine. It fluxuates with the RPM's...more RPM's more and louder groaning and at idle, it is a dull yet louder than the engine humming.
Also when at idle and/or at lower speeds and RPM's the harder I push the brake pedal the louder than same groning noise gets.
I think my power steeering pump is about to die...do you agree and is it connect to the brake pedal some how?
Thanks
Old Jun 5, 2010 | 07:47 PM
jwhitetail's Avatar
jwhitetail
Sounds like that's what it is, and yes there is a relationship to the brake system.
Old Jun 5, 2010 | 09:05 PM
Medic 66's Avatar
Medic 66
Thank you. I thought that the two were related...just by the actions I could feel/hear when driving. Now...can you tell me how they are related? That is I guess the meat and potatoes of the issue...
Thanks, RC
Old Jun 5, 2010 | 11:53 PM
clintbonnie's Avatar
clintbonnie
I assure you check the level of power steering fluid... If it is OK you might try flushing the system before replacing the pump.. per the following method and use Mobil 1 AFT syn Mercon fluid..(available at Auto Zone)...(don't use power steering fluid):
Ford Super Duty Power Steering Flush | Superdutypsd.com
Old Jun 6, 2010 | 02:14 AM
ChunderDownUnder's Avatar
ChunderDownUnder
X2 with the flush. Clean oil makes a big difference. Mine groans as well from time to time. Its a powerstroke thing.
Old Jun 6, 2010 | 06:09 AM
hammer65's Avatar
hammer65
X3 the flush. I just did mine and used 4 qts of Synthetic ATF. I then added a bottle of Lucas PS leak sealer. All squeaking gone. Jim
Old Jun 6, 2010 | 10:24 AM
jwhitetail's Avatar
jwhitetail
I 'am not quite sure on the link between the two, but the expert's will chime in. I know when doing the flush, when you turn the wheel back and forth, you must pump the brake to get it all out.
Old Jun 6, 2010 | 10:58 AM
clintbonnie
Yep... it listed in "step 4" of the link in the procedure.. It helps get the air out of the system..
It also helps to jack up both wheels and support the frame with frame jacks..while turning the steering wheel back and forth..
Old Jun 6, 2010 | 11:43 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
The brakes get boosted by the same pump.
Old Jun 6, 2010 | 07:18 PM
Medic 66's Avatar
Medic 66
About three weeks ago I had to replace my rear brake caliper. Do you suppose that when i did that procedure that air got into the system and affected the power steering pump since the two systems are connected?
Old Jun 6, 2010 | 09:01 PM
jwhitetail's Avatar
jwhitetail
No that should not effect that at all. That moaning is the power steering pump, do a flush and see if that help's.
Old Jun 6, 2010 | 10:14 PM
Visseroth's Avatar
Visseroth
X2 or X3 or X what ever on the PS flush! Sounds like a groaning pump to me!
Old Jun 7, 2010 | 05:09 AM
hammer65's Avatar
hammer65
I had washed my engine down, and someone on this forum suggested that I may have gotten water into the tank. The flush worked. Jim
Old Jun 7, 2010 | 06:19 AM
Visseroth's Avatar
Visseroth
He's referring to the reservoir in the pump. There is a little breather hole in the cap and chances are got some water through the hole into the pump reservoir.
Old Jun 7, 2010 | 11:31 AM
jwhitetail's Avatar
jwhitetail
Great Jim i'am glad that's all it was.
draboo
Oct 3, 2016 01:31 PM
dnkensinger
Aug 25, 2016 11:58 AM
F250TN
Aug 2, 2016 06:37 PM
Rich100
22
May 13, 2016 10:46 PM
senix
Sep 19, 2015 04:47 PM
