knocking...efi problem?
Old Feb 4, 2003 | 03:58 PM
mikefraz01's Avatar
mikefraz01
recently after tearing my manifold off to replace a valve cover gasket i accidently broke some brittle vaccum lines, and may have forgot to reconnect a wire or two, i tried to plug all the empty vacuum spaces because there was no way of reconnecting them, could this result in my new found knocking noise? sounds like a piston knock, the engine does have 145,000 miles on it, and it seems the head gasket is going now too, im saving for a new engine but in the meantime is there a simple solution to this problem to hold me over till i get the coin for the big 8?
Old Feb 5, 2003 | 08:34 AM
steve83's Avatar
steve83
Get some 3/32" ID rubber vacuum line and use it to splice the broken ones.
No vacuum leak or vacuum-controlled system should cause and engine "knock", other than valve tap/dieseling/preignition/knocking from the lean mix.
Old Feb 5, 2003 | 11:13 AM
joetee10's Avatar
joetee10
knocking........bearing problems
rk.ranch
Mar 29, 2015 08:25 PM
bigfish6025
Jun 27, 2014 05:39 PM
toothnet
Aerostar
Dec 13, 2010 12:02 AM
mrfix71
Jun 23, 2007 08:52 PM
351 power
15
Feb 15, 2004 08:13 PM
