Terminal Terminals
Old Feb 4, 2003 | 03:43 PM
Paxcam's Avatar
Paxcam
Terminal Terminals
My original battery gave me four years of trouble-free operation until it bit the dust.
When I pulled the plastic cover off the positive terminal, there it was-- the wonderful world of corrosion.
This got me wondering-- (granted, a precarious proposition)--
why Ford uses a plastic battery shield that hides access to the cells. It forces you pull the terminals to check or add distilled water. I don't want to be surprized again, so I tossed mine.
Ford also uses cheapo copper clamps as battery terminal connectors that are prone to corosion because of the dissimilar metal of the nearby clamping screw. Just a little corrosion caused my screw to freeze, which, in turn, stripped the threaded side of the clamp.
I cut those suckers off and replaced with the old fashioned lead terminal connectors which have zinc-plated clamping bolts.
Okay, this exercise may be utterly **** of me, but I'll sleep better.
I'd like to hear if anyone in the forum has a better idea-- Ford obviously does not.
handyandy123
Nov 9, 2017 12:10 AM
FordmanNJ
6.2L V8
Jan 3, 2015 09:24 AM
esolcz
Jul 4, 2013 07:13 AM
handyandy123
Aug 27, 2010 04:44 PM
handyandy123
Aug 27, 2010 11:19 AM
