log splitter help
Old Jun 3, 2010 | 09:24 PM
93 mix 'n match's Avatar
93 mix 'n match
log splitter help
so i got this log splitter for free today. its a custom made one. the guy said it has a 50 ton cylinder on it. i dont know, but it does look significantly bigger then my neighbors 30 ton one. the problem is the old motor blew up and it needs a new one. i can get a motor easily. the problem is someone told me it needs a gear reduction on it i dont know if thats true or not. can someone shed some light on the situation?
Old Jun 3, 2010 | 11:42 PM
rebocardo's Avatar
rebocardo
I have heard of clutches, but, not a gear reduction. If anything you want the pump spinning faster for higher and quicker pressure. If it does have a gear reduction box, I doubt it is bad so you can reuse it.
Old Jun 4, 2010 | 05:43 AM
ckal704's Avatar
ckal704
Ditto.
I've never seen gear reduction on a factory unit, or a clutch for that matter. But I guess it might be possible with a home built job that the pump capacity is too high so you need a lower rpm input to accommodate it.
But, if you got the unit intact and it didn't have a gear reduction on it already, I don't see the point of putting one on.
You do need a quality shock absorbing spider coupler between the engine PTO and the pump input shaft, however.
Old Jun 4, 2010 | 02:00 PM
93 mix 'n match
thanks. its a 100% custom unit. VERY redneck, but tough. ill have to get some pics. its all made on a giant I-beam. the motor is off of it and long gone. blew the rod out of the case. i got a motor all i need is the coupler.
Old Jun 4, 2010 | 03:59 PM
ckal704's Avatar
ckal704
Tractor Supply or similar stores will have them.
Old Jun 5, 2010 | 04:35 AM
rebocardo's Avatar
rebocardo
Hydraulics | Northern Tool + Equipment
Click on the coupler image.
Old Jun 6, 2010 | 07:35 AM
tjc transport's Avatar
tjc transport
i ain't rite
it it had a gear reduction unit on the engine, the splitter most likely used a dump or garbage truck hydraulic pump
we compensated for the lack of a gear reduction unit on the splitter we built years ago by using a set of drive gears and chain from a motorcycle ..
Old Jun 6, 2010 | 09:49 AM
93 mix 'n match
well the guy kept the coupler from the old motor so im pretty safe there. heres some pics.
Old Jun 6, 2010 | 11:25 AM
tjc transport
i ain't rite
that is almost exactly the same thing we built Louis.
we used a 16 hp 2 cylinder Wisconsin for power
Old Jun 6, 2010 | 12:10 PM
93 mix 'n match
the motor im using is a 14 horse single cylinder. im suprised on how well this thing is built
heres a new problem. it needs all new hoses. which hoses are high pressure and need spcial fittings? and where do i get these hoses?
Old Jun 6, 2010 | 01:41 PM
tjc transport
i ain't rite
the one from the bottom of the tank to the pump with the hose clamps on it is the low pressure suction side. all other hoses are high pressure hoses, even the one from the top of the valve body to the top of the tank.
the only reason you can get away with clamps on that one is because it is an open return so will not have the high pressure that the valved lines will.
66gpw
Jul 11, 2009 11:23 PM
freirefishing
Feb 13, 2008 08:23 PM
scottie2hottie
Feb 2, 2007 10:31 AM
Avanti
Jul 10, 2005 04:48 PM
bigrigfixer
19
May 25, 2005 11:46 PM
