power rear window
Old Jun 3, 2010 | 06:32 PM
stubnessa's Avatar
stubnessa
power rear window
why does it barely move when truck is at an idle? i have lubed the cables and it still only works so so even when driving, for what ever reason the rpm of engine seems to effect the ease of operation.
Old Jun 3, 2010 | 06:47 PM
69cj's Avatar
69cj
You might want to check your batteries and alternator to see if they are up to par?
Old Jun 3, 2010 | 06:58 PM
stubnessa's Avatar
stubnessa
that was the first thing i did was replace both batts and check alt. that is why i was curious if anyone else experienced this issue
Old Jun 3, 2010 | 07:01 PM
69cj's Avatar
69cj
Mine was slow for about 2 months. Happened the day I forgot to totally close the rear window prior to going thru a car wash.
Old Jun 3, 2010 | 07:05 PM
gearloose1's Avatar
gearloose1
There is a whole thread on how to rebuild / repair the motors:
How To Repair the Power Window Regulator / Motor .: Ford Truck Articles
Check voltage and current and verify that the motor is receiving full current and voltage...
If you have bad power going there, a new motor is not going to work any easier.
Old Jun 3, 2010 | 07:06 PM
stubnessa's Avatar
stubnessa
well all i know is that my frustration level is growing to the point that a new motor may be in my future unless someone can give me a good reason for the way it is acting.... thank you for your help
Old Jun 3, 2010 | 07:08 PM
stubnessa's Avatar
stubnessa
sweet i appreciate that thank you i will check it out
Old Jun 3, 2010 | 07:23 PM
bismic's Avatar
bismic
From what I hear, the main reason most dont work is the glass is glued into the lower mount and it comes loose. This will jam the glass in the track and cause it to usually open slowly and sometimes not close. Spraying it with white grease or a dry lube usually makes it work for awhile but the true fix is to replace the rear window or find out what Ford was using to re-glue the window.
Also, sometimes the cable gets "bound up". I believe the motor and cable assembly is around $250 from Ford - if it comes to that for you.
Old Jun 3, 2010 | 07:31 PM
stubnessa's Avatar
stubnessa
i will look into that, however i have not had any improvement after the several different lubes i have tried dry, wet, and cable lube for motorcycles as well. i took the back panel off and watched the motor operate didnt see anything obvious wrong with it i was wondering if rebuilding it is an option i dont mind trying anything b4 buying something
Old Jun 3, 2010 | 08:03 PM
sweeted's Avatar
sweeted
When I first picked up my used 06 the only issue was the rear slider. I noticed on the oasis that the rear slide motor was replaced. So I degreased the cable and glass track and gave it a good bath with silicon spray and it slides very smooth as compared to slow and jerky. What I noticed was the track and cable where over lubricated.
Old Jun 3, 2010 | 09:18 PM
cheezit's Avatar
cheezit
mine does the same thing latly it has been working good so I have left it alone. I tried to spray it with all kinds of stuff. nothing seemed to work. I did notice that after it rained it starting working correctly.
TNT
Apr 21, 2013 09:51 PM
DanielT28
Sep 16, 2012 11:27 PM
knash0727
Texas Chapter
Feb 14, 2010 09:34 PM
to many oft
Virginia Chapter
74
Apr 17, 2007 06:07 AM
Nillabean
Feb 8, 2004 07:52 PM
