Today My psd didn't want to start, tried several times and it would crank and yet not start even with plenty fuel in the tank. I had to get a ride from the job site and later I tried one more time and it started so I drove it back home. I heard of a sensor on early psd that would make it not start but this is a 05 with only 50k miles on it, what could cause this?
I had the same thing happen recently. It turned out to be a failed IPR. Also had to change the plug to the IPR.
What's an IPR?
I tried it again and it will start every time (yes there is fuel in the tank ) so I think it could be the shifter wasn't sitting all the way i park. I also found the vacuum pump would not quit running and one the connections near the oil fill cap was disconnected but this shouldn't keep it from running right?
