1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
05 f250 psd will not start
Old 06-03-2010, 06:14 PM
93FordCTD's Avatar
93FordCTD
93FordCTD is offline
Today My psd didn't want to start, tried several times and it would crank and yet not start even with plenty fuel in the tank. I had to get a ride from the job site and later I tried one more time and it started so I drove it back home. I heard of a sensor on early psd that would make it not start but this is a 05 with only 50k miles on it, what could cause this?
Thank You.
Old 06-03-2010, 07:14 PM
billtrev's Avatar
billtrev
billtrev is offline
You might want to check out the "Trouble Shooting a No Start Condition"
in the 6.0 forum Tech Folder.
Old 06-04-2010, 12:22 AM
redford's Avatar
redford
redford is offline
Received 1,597 Likes on 933 Posts
Originally Posted by 93FordCTD
...... I heard of a sensor on early psd that would make it not start .....
That would be the CPS, but it was on the 7.3L Power Stroke.
Old 06-04-2010, 05:24 AM
senix's Avatar
senix
senix is online now
Received 1,464 Likes on 1,044 Posts
oil fired injectors, so when was the last oil change? Verify level of oil.
Old 06-04-2010, 05:46 AM
93FordCTD's Avatar
93FordCTD
Will do all of that and report, Thank You.
Old 06-04-2010, 06:31 AM
gearloose1's Avatar
gearloose1
gearloose1 is offline
Plus check if it has fuel?
Old 06-04-2010, 07:23 AM
SturgeonHunter's Avatar
SturgeonHunter
SturgeonHunter is offline
I had the same thing happen recently. It turned out to be a failed IPR. Also had to change the plug to the IPR.
Old 06-04-2010, 09:00 PM
93FordCTD's Avatar
93FordCTD
What's an IPR?
I tried it again and it will start every time (yes there is fuel in the tank ) so I think it could be the shifter wasn't sitting all the way i park. I also found the vacuum pump would not quit running and one the connections near the oil fill cap was disconnected but this shouldn't keep it from running right?
Thank You.
Old 06-06-2010, 01:57 PM
SturgeonHunter
[quote=93FordCTD;8966572]What's an IPR?
Injection Pressure Regulator
Old 06-07-2010, 07:00 PM
93FordCTD's Avatar
93FordCTD
as it turns out it was the shifter or the cable, can I adjust this or should I just replace it?
Thank You.
