Reverse shackle kit question
Old Jun 3, 2010 | 02:19 PM
DaytonaTunnel's Avatar
DaytonaTunnel
Do I really need the panhard rod ? My truck already has a 4" lift, Sky Mfg. supplied me with a bracket to compensate for the added lift of the reverse shackle kit. It looks identical to the bracket that came w/ my 4" lift.
I can't help but think of my fleet of lifted '79's w/o a panhard rod, and if I really even need it ? The reverse shackle kit will really stabilize the front leafs, making them just like my 79's (shackle were it belongs). Isn't the real function of the p/h rod to stabilze the front leafs using the F-250 TTB shackle system ? Plus it will look terrible, bracket bolted to a bracket !!!
Opinions......................
Old Jun 3, 2010 | 05:35 PM
superduty4x4's Avatar
superduty4x4
I wouldn't run without it myself, but to each his own.
Old Jun 3, 2010 | 10:14 PM
fordboyoffroad's Avatar
fordboyoffroad
it becouse the 79 drag linck gos front to back and the 80s and 90s gose side to side the stering trys to pull the front end side to side i would keep it ore it will be all over the road
Old Jun 4, 2010 | 08:55 AM
Fullcrew7.3's Avatar
Fullcrew7.3
I put it on mine, but apparently, it's not absolutely necessary. With the shackle in the front it IS absolutely necessary.
Old Jun 4, 2010 | 09:00 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
You absolutely do not need it.
The leaf springs securely hold the axle in place.
The only reason the factory trucks have a track bar (or panhard) is to eliminate bump steer because of the cross-over steering setup.
If you can live with a little bit of bump steer, then you certainly don't have to have a track bar. Unless you're going to go to the lengths of making the track bar perfectly parallel to the drag link, then there's really no point of having it anyway.
Old Jun 4, 2010 | 02:18 PM
DaytonaTunnel
A little bump steer aint no big thing. It's a 1ton truck with lots of lift, the body will sit on top of the 37's when the shackle kit is installed. I don't expect it to ride like an Accord.
Old Jun 4, 2010 | 03:13 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I never had any bumpsteer with this.....
Maintained the track bar and as you can see, it's parallel with the draglink.
Old Jun 4, 2010 | 03:29 PM
crash1's Avatar
crash1
i would like some more pics of that truck.Looks like mine use to.I miss it
Old Jun 4, 2010 | 05:16 PM
DaytonaTunnel
Great looking truck. Any chance of some closer pic's of the front suspension ?
Old Jun 5, 2010 | 12:34 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
ford4x4s
Sep 4, 2011 03:23 PM
KG32A
May 20, 2011 01:18 AM
oneofakind97
Offroad & 4x4
Oct 8, 2008 09:43 PM
skittlejr
56
May 22, 2007 07:25 AM
conter4x4
Offroad & 4x4
18
Sep 20, 2005 10:24 AM
