Stout big blocks.
Old Jun 7, 2010 | 06:17 AM
monsterbaby's Avatar
monsterbaby
Thunderjet was just the name put on any old passenger car 429 and ain't anything special.
Basically any of the standard heads can be ported to support good hp (over 600hp fairly easily) exception is stay away from D2VE casting, those are the worst of all the heads. you also want to stay away from teh FI heads (E7TE and F3TE) you just need to buy the pistons to get the comp ratio you want with whichever heads you go with. I prefer the D3VE heads for strokers if your staying with stock heads just due to the ability to keep the compression in a reasonable range without a huge dish. Example with a 521 (4.3 stroke 4.360 bore) and D0VE heads you need a 24cc dish to obtain a 10.75:1 compresion (actually too high to run pump gas but COULD be done) or more legitimately a 38-40cc dish to be a pump gas friendly engine. But with D3VE heads a 20cc dish will make it pump gas and easier to find. Bigger stroker makes it even worse (on a 557 and D3 heads you can run a 34cc dish and run pump gas, with D0VE heads even a 40cc which your not going to find would still be well over 10:1)
Now for best factory iron you would want D0OE-R (CJ, SCJ) or second best D2OE (PI heads) but those are hard to find and high dollar.
Personally I would save my money and buy a good set to begin with. TFS streets are decent especially with porting several guys are making well over 750hp with them or for more kick a set of Kaase P-51 heads that Jon got over 700hp out of a 521 UNPORTED.
Old Jun 7, 2010 | 10:06 PM
Red-Tail's Avatar
Red-Tail
I am lined up to buy a 1970 flatbed f350. it is in really good shape, and has low miles. the cab is solid, the doors have a little rust in them, but not too bad. I'm only paying 675 for the truck, so its not a large cost to me.
I had a question about the engine. It has a 360 ci in the truck and I am trying to find out if this would be a heavy duty four bolt main, or a two bolt main block. Anyone have an idea? If it is a four bolt, I was thinking of a stroker kit to put the cubes up a little bigger, any good hints for a 360 stroker?
btw, this is the 2v 360, so would those heads junk if I wanted to pump the hp up?
Old Jun 7, 2010 | 10:32 PM
bamaf150's Avatar
bamaf150
wow, you are all over the place, from 1200+ hp to mild lol. A 360 with a 390 crank and rods=390, with a 428 crank=410 merc. IINM a 360 can be bored .030 oversize and with the 428 crankshaft you get 416 cid. The heads should work fine unless you are wanting the crazy hp again.
Old Jun 7, 2010 | 10:54 PM
Red-Tail's Avatar
Red-Tail
lol, yeah, I kinda do that. first I was looking for a block to buy, but now I have a truck with a block in it, so . Just out of curiosity what hp will a 360 block hold? at first I was looking for a block to be able to carry 1200 if I ever got there, but I think I'll go crate motor if I do that.
Old Jun 8, 2010 | 06:26 AM
Hickfied's Avatar
Hickfied
Is your truck an auto or manual tranny?
If it is manual (easier to do an engine swap as you would only need a bellhousing) just go get a junkyard 460 from a latermodel truck. Then get a set of C8, C9, or D0 heads and have them freshened up. Throw on a RPM intake, headers, and a carb, and you can have fun while you build your 1200HP motor.
Old Jun 8, 2010 | 09:32 PM
Red-Tail's Avatar
Red-Tail
Ford Racing Motor- 460 Stroker (522CI) 900 hp plus 400 nitros shot
I wish I had the budget for this monster.
Old Jun 8, 2010 | 09:40 PM
bamaf150's Avatar
bamaf150
The FE forum and others here will know better than I do but I'm confidant that 375-400 hp is easily attainable from a 360-390 FE block.
Old Jun 8, 2010 | 10:25 PM
Red-Tail's Avatar
Red-Tail
yeah, 400 is pretty easy from what I have gathered. Cam, headers, intake, valve job, good carb and your're there.
Old Jun 9, 2010 | 05:22 AM
monsterbaby
Originally Posted by Red-Tail
I wouldn't believe that guy for a half second if he showed me a dyno sheet. 900hp WITH nitrous MAYBE.
A. he doesn't have a clue what is in that motor. A thick walled truck block? No such animal and then to claim it isn't honed? then that means it wasn't put together right to begin with, you MUST hone it to put in new rings. Next it would have ot be bored or something to be a 521 (521 is 4.390 bore which is .030 over)
B. to claim 900hp on pump gas? using SVO heads? I seriously doubt it. kaase has done it with his B9 heads but even ported A460 heads aren't running pump gas when making 900hp and since he mentioned it has an edelbrock single plane intake he isn't running A460 heads especially since he called the carb a 1000cfm it isn't a dominator and AFAIK ALL of the A460 intakes are dominator patterns or tunnel rams. Most likely IF it's even a stroker, it probably doesn't have a billet crank but even if it does it probably has the old A429 heads or at best the SCJ alum heads so I would expect probably around 700hp MAX
Basically I would stay WAY away from that motor. The guy that wrote that ad doesn't have a clue and several things don't match up so either someone soldhim a bill and he doesn't know the difference or I wouldn't trust the guy put it together right.
And for waht he is asking you can buy a FRPP brand new crate motor rated at 625hp from ford and it is NEW. and it will run on pump gas.
Old Jun 9, 2010 | 10:49 AM
mwvdub's Avatar
mwvdub
900 hp with 11:1 Ross pistons seems like a stretch to me.
Old Jun 9, 2010 | 12:12 PM
Red-Tail's Avatar
Red-Tail
I'm glad you guys are here. It's really good to have some people to cut through the 'seller stories'
*edit* will a 428 intercepter intake fit on a 390-360 block?
Old Jun 14, 2010 | 11:45 PM
Red-Tail's Avatar
Red-Tail
I have a question about cranks, will a 429 crank fit in a 360? what cranks will fit in the 360 to make it bigger?
Old Jun 15, 2010 | 08:11 AM
  #28
Rockstone's Avatar
Rockstone
Yes
429 is a different engine family, so, no. 390 and 428 cranks will work.
Old Jun 18, 2010 | 12:48 PM
  #29
Red-Tail's Avatar
Red-Tail
I am lined up to buy a 1977 f250 with a 1962 390 engine in it. I'll have more info on the engine later, but would that engine have come from a t bird or another truck? any specks on a 62 390? thanks
Old Jun 21, 2010 | 02:46 PM
  #30
Red-Tail's Avatar
Red-Tail
So I have some more questions for you all. I had someone contact me and they sent me a list of engine parts they have, would you look through and point out the good stuff? or what is worth the effort of buying and fixing up? what is the best for hp.
HEADS; EDC, COAE-C, CIAE-A, C4AE-G, C4AE-H(427 low riser), C6TE-G, C6AE-J,L,R,U, C7AE-A, C7JE-A, C7TE-A, C8AE-H(390 GTand non GT), C8OE-N (CJ), D2T3-AA, $100-$800., 390 BLOCKS; 63, 65, 66, 67, 68, 69, 70, 72, 73, 74, 75, $100-$300.(some are short blocks). 428 BLOCKS; 66, 67, 68, 69, $500-$3000. (some are short blocks). 427 BLOCK; (1) NOS hyd lifter side oiler block $4000., 390 cranks, $75-$125, (1) 427 cast crank $300, (2) 428 cranks $350-$400., INTAKES; early cast 4V, several @ $50 ea., 69 428 CJ $300, 67 PI aluminum $450, 66-68 S manifolds $75 ea., Edelbrock performer $175, F427 $275, Streetmaster $175., MISC; rods, pistons, cams, rockers, exh manifolds, headers, carbs, distributors, oil pans, valve covers, and etc. $10-$350.
xtraparts
Jul 27, 2013 08:53 PM
tonylo
Mar 10, 2012 09:13 PM
windsor-f150
Sep 8, 2010 09:18 PM
BlueOvalRage
13
Mar 27, 2002 09:46 PM
