Big block descions
Old Jul 14, 2013 | 08:59 PM
xtraparts's Avatar
xtraparts
Big block descions
Hey guys I'm building a 47 ford 1/2 ton rod. I'm trying to keep the purchasing of large hard parts to a min. I have a 400 big block, 390, 69 360. Sitting a in shed out at the farm. I've just started tearing the truck down. But I don't know a thing about big blocks, but the basics. Lol. Any ways I just want to put a hefty enough amount of power for the cubes. What are your thoughts?
Old Jul 16, 2013 | 07:59 PM
dimora's Avatar
dimora
I had this thought pop into my head:
https://www.ford-trucks.com/forums/1...g-prepped.html
If you want to run your existing 400 block and just bore it and have it gone over:
I like these:
http://www.tmeyerinc.com/aussieheads.html
Or some aluminum CHI heads...
and these:
http://www.tmeyerinc.com/400ford.html
My build is in my signature.
Old Jul 17, 2013 | 07:01 PM
BuzzLOL's Avatar
BuzzLOL
.. Yes, the 400 is basically like a tall deck 351 Cleveland 'small block'... proper pistons (modified 351C pistons) and a mild performance cam can net you a cheap 350-400HP or more depending on the year of the 400... '70-'71 400's have the best flowing stock heads... you end up with something akin to a ' 400" Cleveland '... and it's 80 pounds lighter than a true Ford 'big block'...
Old Jul 27, 2013 | 08:53 PM
wyoming4x4's Avatar
wyoming4x4
cleveland piston in 400 ford.
cleveland piston have a smaller piston pin. have to install a bushing in the 400 rod to fit the smaller pin. Not a big problem for a decent machine shop. done this with couple of engines. tim meyer pistons are a simpler route for upgrades but either will work. compression up and yes you will upgrade hrspwr double with decent cam. upgrade your cam bearing to tim meyer bearings, great and simple upgrade for street driven engines and performance. I have many photos in my albums and photobucket up my cobrajet headed 400 ford with cleveland pistons if any questions. have a good day.
71dusterdan
Dec 28, 2006 01:55 AM
mswift
17
Nov 6, 2006 06:53 AM
pud
Sep 7, 2006 05:51 PM
hurri10209
Mar 22, 2004 06:58 PM
macks
21
Nov 2, 2001 09:49 PM
