got nothing
Old Jun 2, 2010 | 09:07 PM
red rock 78's Avatar
red rock 78
got nothing
yesterday i cranked my 78 f 150 ran fine for about 5 minutes.Today i stuck the key in and got nothing but a click i checked the lights they came on.When i tried them again everything was dead i checked the battery it is charged. Could there be moisture somewhere it did rain today or maybe a short somewhere.
Old Jun 2, 2010 | 10:56 PM
montana_highboy's Avatar
montana_highboy
Check the fusible links coming off the battery side of the starter solenoid.
Old Jun 3, 2010 | 12:49 AM
75F150360's Avatar
75F150360
neutral safety switch
check that the neutral safety switch at the bottom of the steering column hasn't slipped. if that is okay then check the starter solenoid.
Old Jun 3, 2010 | 10:31 AM
worldwideautohelpinc's Avatar
sounds like your starter solenoid. make sure it is tight against the body where it's mounted that's how it is grounded.
Old Jun 3, 2010 | 02:02 PM
red rock 78
thanks for the feedback i will check these things and will post later.
Old Jun 3, 2010 | 02:49 PM
dogguira's Avatar
dogguira
Check to make sure your ignition switch wires are tight.
Old Jun 3, 2010 | 03:24 PM
Customcab's Avatar
Customcab
Heck I would also check the positive cable to the starter; it could be loose.
Mitch
Old Jun 3, 2010 | 09:32 PM
red rock 78
I took the stater solenoid off the firewall and cleaned behind it.I checked all wires and fuses on solenoid reconnected batt. and it fired right up.Thanks for all your help.Hopefully that solved it if not I'll check the other things.
cherrybomb37
Jan 11, 2015 06:14 PM
nekomejia
Sep 18, 2014 10:22 AM
nolanb
Jun 21, 2010 10:53 PM
electricheaven
Jun 10, 2010 07:59 PM
davelong667
Apr 16, 2007 07:47 PM
