antifreeze
Old Jun 2, 2010 | 07:52 PM
Mrob2960's Avatar
Mrob2960
antifreeze
Has anybody used Amsoil's antifreeze in a 7.3 diesel?
Old Jun 2, 2010 | 08:59 PM
cps's Avatar
cps
Its Expensive and with other brands out there just as good why spend the extra?
Old Jun 2, 2010 | 09:22 PM
Mrob2960's Avatar
Mrob2960
I guess I should of asked this type of antifreeze ,since it is not what came in it. What brands are just as good?
Old Jun 2, 2010 | 09:30 PM
clintbonnie's Avatar
clintbonnie
A Big Welcome to the Forum... Here is a "Thread" about coolant in a 2002 .. you might find interesting..
https://www.ford-trucks.com/forums/4...or-yellow.html
Old Jun 2, 2010 | 10:00 PM
Mrob2960's Avatar
Mrob2960
Thanks for that thread. Mine also came with the green coolant in it. This thread is telling me not to use pg type coolant. Its amazing how many different opinions you can get. Thanks again
Old Jun 2, 2010 | 10:02 PM
Stewart_H's Avatar
Stewart_H
What year is your truck?
If it's a late '99 or up, I'd recommend a heavy duty Extended Life Coolant.
https://www.ford-trucks.com/forums/9...ml#post8936443
Stewart
Old Jun 3, 2010 | 01:20 AM
clintbonnie
If you switched to a Extended life coolant, be sure to completely flush the green stuff out.. There are drains on the block you should use..
Old Jun 3, 2010 | 02:25 AM
homesteader's Avatar
homesteader
I use rottela elc in my truck.
Old Jun 3, 2010 | 06:02 AM
Visseroth's Avatar
Visseroth
Nice, good to know as I am still fiddling with my green coolant to try and get it to where the boiling and freezing points need to be but what is this SCA additive or what ever it is and where do you get it?
And if one was to change their type of coolant how do you THOROUGHLY flush the system? Stick a hose in the tubes and start pumping tap water in?
Old Jun 3, 2010 | 07:12 AM
HD Rider's Avatar
HD Rider
I am an Amsoil dealer so I got some for one of my cars just to try it. I don't stock it or recommend it because it's expensive and there are other options that are just as good. I won't be useing it in my truck.
I am still useing the green stuff in my truck. It's best to run a coolant filter with green stuff to catch any silicate drop out (sand) and protect the water pump. You should check the PH with test strips. They are available at Napa pretty cheap. Keep the PH above 7.5. If it drops to 7.5 or below, then you need to add SCA (suplimental coolant additives). If you are running a coolant filter, they are available with or without a SCA pack in them, or it is available in a bottle from Ford or any quality parts store such as Napa.
Old Jun 3, 2010 | 11:03 AM
clintbonnie
I would not worry about the boiling or the freeze points..(if you have the correct amount of anti-freeze in your system).. The main thing to worry about is if the coolant has the right amount of SCA additive (if you are using the Green coolant).. Without the right amount, you could have a hole develop from cavitation thru your engine block.. Here is some good info:
http://www.forddoctorsdts.com/articl...icle-09-02.php
Coolant changing instructions... - Diesel Forum - TheDieselStop.com
http://www.dieselmanor.com/fleetguard/fg_teststrips.asp
Old Jun 3, 2010 | 11:59 AM
Stewart_H's Avatar
Stewart_H
No longer need to link to TDS. Here is Gooch's flush procedure and all the ELC info he's posted over the years compiled into one thread here at FTE.
With the E99 rig, ELC is not recommended.
https://www.ford-trucks.com/forums/9...ml#post8935201
Stewart
Old Jun 3, 2010 | 04:30 PM
Visseroth's Avatar
Visseroth
LOL, well I ask because I've been trying to get my boil and freeze points where they need to be for my area but I will go get some test strips. I didn't know anything about test strips but will learn much more when I go to pick them up today. I changed my water pump and put more water then coolant in, or i believe I did.
Sorry, didn't mean to hijack your thread. You pulled up some good need to know information that I'm taking in like a spung.
Melinda Jacobs
Escape & Escape Hybrid
Nov 14, 2014 09:06 PM
tbugher62
Apr 4, 2014 03:54 PM
fordpride
30
Feb 12, 2012 10:01 PM
MO51
Aerostar
21
Jan 20, 2003 11:37 AM
nckracer
Jan 13, 2002 05:04 PM
