hows the dash come off
Old May 31, 2010 | 11:29 PM
another ford's Avatar
another ford
i have a 2005 sd 6.0 air vents stopped working they went to defrost changed vacum pump now floor vent works but the dash vent still dont work need some help and direction
Old Jun 1, 2010 | 05:38 AM
gearloose1's Avatar
gearloose1
Start checking for a vacuum problem --- either motors / controls jammed or a leak.
Start with the switch on the dash and work your way over to the heater controls.
Use a vacuum gauge to verify sufficient vacuum.
Old Jun 1, 2010 | 06:48 AM
Cowboy65's Avatar
Cowboy65
Check out the link below for some good info on dash removal.
http://www.brandmotion.com/manuals/F...ation_2007.pdf
Old Jun 1, 2010 | 08:40 AM
teppler's Avatar
teppler
I have removed my dash several times and it is very easy but the first time is nerve racking as you envision snapping off some plastic piece and costing you a fortune to replace the entire dash it snaps right off but sounds terrible but no damage so far..Good Luck
Old Jun 1, 2010 | 09:06 PM
another ford
thanks you guys i will give it a try!!!
Old Jun 1, 2010 | 09:08 PM
sammy77's Avatar
sammy77
Why so many times??
Old Jun 2, 2010 | 08:51 AM
teppler's Avatar
teppler
Well first time was when I replaced my stock radio/cd player with aftermarket, then second time to send unit back for replacement then third time when squirrel got under dash and chewed wires had to repair . Now the valve controlling heater /defroster valve is slow so will be pulling it again soon....Oh just a thought don't forget you have to pull ***** off before removing dash...
Old Jun 2, 2010 | 04:35 PM
sammy77's Avatar
sammy77
You pulled entire dash for radio install?? By the way how the hell did a squirrel brake into your truck??
Old Jun 2, 2010 | 10:12 PM
teppler's Avatar
teppler
I could pull the old radio but to install the new one had to pull the dash, my hands are large and needed the extra room. As for the squirrel they were way to friendly I assume they have been hand fed and one got in I'm thinking while I was unhooking the 5th wheel. Cost me $500 and insurance company over $2000.
Old Jun 2, 2010 | 10:35 PM
whalerron's Avatar
whalerron
When you remove the dash, be very careful that you do not lose any of those little plastic attaching clips. Some of them fall off easily when the panel is removed and Ford doesn't sell them individually. You gotta buy the whole danged panel!!!!
