6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Navigation Radio
Old Jun 2, 2010 | 06:00 PM
David1986's Avatar
David1986
Navigation Radio
Just replaced my factory single disk Cd player with a Pioneer Navigation Radio. Well worth the $800 I spent versus Ford's $3,000 unit. I tried purchasing one through the dealer at their cost and it was $3k. The pioneer unit has CD,DVD,Bluetooth and Navigation.
I also installed 4 new Kenwood 6x8's two months ago for $120.00. I have $1,000 in the system that sounds better than the Ford factory $3K system.
Thought about adding a AMP and Sub, however the Pioneer system has a AMP built into it. The company that installed it said a AMP wouldn't be worth spending the money on with the sound performance that I already have. The Sub would give it more bass, but I have a Reg Cab and don't really need the Sub.
This is a Great system for the money!
Old Jun 2, 2010 | 08:49 PM
RoadJunkie's Avatar
RoadJunkie
Model number?
Old Jun 2, 2010 | 11:23 PM
jeff7825's Avatar
jeff7825
Which Pioneer unit did you get. I had the AVIC F700bt, and it was a little buggy, but a pretty good unit overall. I am thinking about getting one of the new AVIC units sometime soon to replace the one I sold. Those factory nav units sure to fetch the money. The last couple of ones I have seen on Ebay both sold for over $1,000. I just cant see paying that when you can buy a much nicer aftermarket unit for half the cost.
Old Jun 3, 2010 | 05:18 AM
senix's Avatar
senix
did it fit ok in the factory hole? I have the 6 disk with sat in mine.
Old Jun 3, 2010 | 07:43 AM
David1986's Avatar
David1986
Here's a picture of the installed unit. The model is a AVIC-X920BT/XNUC. The believe the screen size is 6.3. I looked at several different units that were smaller, cheaper, however I wanted a factory clean look. This unit seem to be the best to to acheive what I was looking for.
Old Jun 3, 2010 | 08:03 AM
senix's Avatar
senix
great install, that is what I am looking for myself...looks like it is time for another upgrade!
Old Jun 3, 2010 | 08:36 AM
jeff7825's Avatar
jeff7825
Looks good. I was looking at getting the X910 just because I think that having the volume **** looks a little more factory.
Old Jun 3, 2010 | 12:26 PM
David1986's Avatar
David1986
I was looking at a similar unit that had a volume ****. I would have prefered having the **** for the volume control versus the push button.
Old Jun 3, 2010 | 01:51 PM
astamp78's Avatar
astamp78
Do these aftermarket units still make use of the steering wheel controls? That looks really nice installed and is very tempting!
Old Jun 3, 2010 | 02:30 PM
Brandon D's Avatar
Brandon D
Lead Foot User
I thought about doing a similar upgrade but the cost to make the Satellite radio work with the new unit was going to be as much as the unit itself and then when they told me the steering wheel controls would NOT work it made the decision for me. I opted for the sub and amp upgrade and am very happy with my decision. I'm sure there is a way to make the steering wheel controls work but the installers at my local shop had no clue. I will say that Ford is definately more user friendly than Chevs are. I had an 07 2500HD and they route the power for the airbags through the radios now so it was going to cost me over $800 just to bipass that and make everything work, what a stupid idea that is.
Old Jun 3, 2010 | 03:10 PM
David1986's Avatar
David1986
Not for sure since my truck doesn't have steering wheel controls. The installer told me that some units work with steering wheel controls and some don't. I would ask a installer at your local electronics store, if the unit will work.
My unit also came with the Ipod connection and the bluetooth option. The bluetooth ( or Ford's Sync) works Great. My wifes Expedition has the Ford Nav unit with Sync and the Pioneer unit does everything the Ford system does.
One day in the future, I want to add a 8-10 Sub in my center console. My only concern with this is the vibration in the console with it being made of plastic.
Old Jun 3, 2010 | 03:40 PM
jeff7825's Avatar
jeff7825
You can make them work, you just have to buy a separate module.
Old Jun 3, 2010 | 08:45 PM
elongate's Avatar
elongate
Interresting, sorry for the highjack but could you post up some info on this. I've got the factory 6 disc and want a little more punch with the music i listen to and want to keep the factory unit because of the SYNC. Thanks.
Old Jun 5, 2010 | 12:11 AM
LaxPlaya21's Avatar
LaxPlaya21
To the OP... that head unit looks great! Very clean, and I am sure it definitely has some power.
And Elongate, depending on your budget you have many options. I just recently did a decent upgrade to my system. I purchased all new Diamond door speakers to fit in the stock placement. Then I added two additional tweeters flush mount on the dash for reflective sound. They are powered by one 600 watt 4 channel amp. Then I for bass, I added a JL audio stealthbox that fits under the back seat. It houses a 13.5 inch single sub that pounds! It sounds super tight, nothing like two 12's. More like really tight 10's that go deep. That is powered by a single Rockford 500x1 amp. Lastly all four doors and the rear wall of the cab is all tightened up with Dynamat to kill any vibrations. This also slightly reduced existing rattles and some road noise.
Here is a pic of the sub enclosure
Old Jun 6, 2010 | 11:42 PM
Brandon D's Avatar
Brandon D
Lead Foot User
Here's the link to the thread I had on it. I apologize that I still have not added pics of the finished product. If someone can tell me an easy way of adding them then I'll throw a few on the original thread.
https://www.ford-trucks.com/forums/8...uestion-2.html
