Offroad & 4x4
Broken rear spring
Old Jun 2, 2010 | 04:44 PM
ignis's Avatar
ignis
Broken rear spring
Mechanic called me today and told me that the clanking noise I'm hearing is from a broken rear spring. They want to install "quick struts" for $510.
Is this really necessary? I've been driving it like this for weeks and the only difference I've noticed is the clank noise when I hit a bump.
If this is necessary, is this a pretty easy job for a DIY'er?
2002 Ford Explorer
Old Jun 2, 2010 | 07:11 PM
alpha/omega's Avatar
alpha/omega
dont worry about it.
Your suspension really isnt important for your truck to function properly.
Old Jun 2, 2010 | 08:55 PM
fatdan460's Avatar
fatdan460
lollerz!!!!
Old Jun 3, 2010 | 04:41 AM
Bender99's Avatar
Bender99
Weld the spring back together like tinian!
Old Jun 3, 2010 | 10:40 AM
Prozon's Avatar
Prozon
If it makes you feel any better he bought new springs for his F150 lol.
As for Ignis, get it fixed.
Old Jun 3, 2010 | 02:28 PM
fatdan460's Avatar
fatdan460
do 2002's have coil rears with irs? or is that just the expeditions with irs?
either way, to the o/p, between this and your other post, i say again take it to another shop. if this is the same one telling you that bald tires on one end of an awd will destroy your center diff, he might have his head up his *** about your noisy broken spring
Old Jun 3, 2010 | 09:39 PM
Prozon's Avatar
Prozon
I assume they're coils...
But that mechanic is probably picking every little thing cause he knows you probably don't know any better, and he can charge you ridiculously for the work.
Old Jun 3, 2010 | 11:09 PM
HillbillyDeluxe81's Avatar
HillbillyDeluxe81
He probably has a 2 door..... They carried over the solid rear axle for a few years after the 4 door switched to IFS in 2002. But most of the 2 door models used a composite monoleaf. If the leaf was actually "broken"......you would think it would be noticeable.
Personally...I would like to learn more of this mysterious "quick strut"
Old Jun 4, 2010 | 10:44 AM
Prozon's Avatar
Prozon
Its not a broken leaf spring.. A quick strut is a replacement for a broken strut.
Quick-Strut®
Quick and easy... remove and replace one piece! No need to take apart entire assembly. No need to compress coil springs.
Monroe Quick Struts
NW 150
Oct 6, 2014 07:12 AM
blue250PSD
Large Truck
Aug 31, 2014 05:30 PM
blue250PSD
Aug 23, 2014 12:42 AM
johaner78
Sep 7, 2011 09:45 PM
BroncoPimp94
Feb 9, 2010 06:45 PM
