Sponsored by: Auxito
Alignment?
Old Jun 1, 2010 | 08:01 PM
david350's Avatar
david350
Alignment?
My truck pulls to the right going down a smooth rode. Always have to hold the wheel to the left a bit to keep it straight, very annoying. Also my steering wheel hardly turns back to straight after any kind of turn. Will just a standard alignment fix my problem? I got a new idler arm in October, they said it needed a pitman but never put one in. How much will an alignment run me, time involved? I only put 40 miles a week on it so I'm guessing it won't kill me for now.
Thanks!
Old Jun 1, 2010 | 10:10 PM
trsimmons25's Avatar
trsimmons25
If it needs a pitman arm that could be your problem depending on how bad it is. Most alignment shops will not align a vehicle with bad front end parts. Check your air pressures and cross rotate your front tires also. There is the posibility that the idler arm was not installed correctly.
Old Jun 2, 2010 | 09:05 PM
steve(ill)'s Avatar
steve(ill)
could be any of the above, could also be toe in or toe out due to lower ball joint wear. Best bet is to let a shop put it on a lift for 20 minutes and check things out and tell you what is wrong.
Old Jun 19, 2010 | 06:05 PM
fordmoco's Avatar
fordmoco
I have a 2001 ford excursion and went to get an alignment and the mechanic slacked off while doing so, he never used the impact gun to tighten the adjusting sleeve thus stripping it out, before i had realized that was my problem I as well had trouble with the steering wheel coming back straight, and also had a slight pull to the right as well... I had a very "Calm Talk " with the manager of the service station explaining how this could have evolved me in an accident, and came out of there with all new front end parts. Good luck!
jonrjen
6.7L Power Stroke Diesel
Feb 20, 2015 07:26 PM
duggyb
13
Dec 23, 2013 06:10 PM
'04 4.0 XLT
1983 - 2012 Ranger & B-Series
Jul 10, 2013 01:20 AM
OleGrouch
Aug 17, 2012 10:37 PM
BlackNGoldRules
Aug 9, 2010 07:14 PM
