Limping E4OD Reset Itself.
Old Jun 1, 2010 | 09:58 AM
killforfood's Avatar
killforfood
I was pulling our 27’ trailer to the campground this weekend when a hard 2<SUP>nd</SUP> to 3<SUP>rd</SUP> shift put me into limp mode. It was kind of my fault for manually shifting at too high of an rpm into 3<SUP>rd</SUP> gear. The gear indicator has never read right since last winter when a bunch of ice and mud froze around the shift linkage. It got so bad that I had to crawl under and bust off clods of mud and ice just too manually shift gears. Now when it indicates drive, I may really be in 2<SUP>nd</SUP> gear. That’s where the confusion comes in. I had just crested a long hill and pushed the lever into what I thought was drive but it was still hung up in 2<SUP>nd</SUP> gear. The revs were coming up fast but no shift. I quickly realized the problem, let up on the gas a bit and shoved it fully into drive. It was an extremely hard shift and felt as if I had done a neutral drop. The overdrive off light immediately began blinking. That’s the first time I’ve ever felt a tranny in limp mode and for the next couple days every shift nearly gave me whiplash. Anyway a couple days later I drove into town to have the codes pulled and it reset itself before I got there and showed zero codes.
So, did I get lucky and life is good or should I be concerned that some permanent damage has occurred and needs addressed?
outlawspeeder88
Mar 3, 2015 06:00 PM
Jack G 1916
6.7L Power Stroke Diesel
Nov 29, 2012 11:17 PM
38-72
17
Nov 3, 2011 07:10 PM
polyeric
Jan 28, 2010 06:41 PM
zeus77
18
Mar 20, 2007 01:39 PM
