Injectors going bad?
Old Jun 1, 2010 | 08:21 AM
RippedF350's Avatar
RippedF350
I am not really familiar with this subject, so please correct me where I am wrong.
Almost every time I turn the key to glow plug my truck, I can hear an injector sqeak, or at least that is my logical conclusion.
What does this mean?
Old Jun 1, 2010 | 08:57 AM
bdrummonds's Avatar
bdrummonds
Need more info on said injector squeak..... Our injectors work off of hydraulic pressure. I.E. if the engine is not turning there is no hydraulic pressure built to "fire" the injectors. Now each injector does have a electric solenoid on top that may be subject to fail, but unless you have a tremendous amount of miles onyour injectors it is highly unlikely.
How many miles? When was the last oil change? Is oil level full, correct grade and weight?
Old Jun 1, 2010 | 10:08 AM
rat49f6's Avatar
rat49f6
My fuel pump squeeks
have someone else turn the key on and u listen to the pump its under the drivers door inside the frame rail
Old Jun 1, 2010 | 11:23 AM
clintbonnie's Avatar
clintbonnie
Your vacuum pump also make weird noises with the key on, for several seconds.. (located under the hood near passenger side battery..)
bduemig
Jul 24, 2012 08:32 PM
79OldBone
32
Nov 11, 2011 10:45 AM
kenlippold
Mar 6, 2011 04:29 PM
nookiemonster55
Apr 4, 2010 03:35 PM
Talyn
Oct 31, 2009 09:09 AM
