SD injectors in a OBS?
Old Nov 10, 2011 | 12:49 PM
79OldBone's Avatar
79OldBone
So since the super duties have the bigger injectors and are split shot... could I just let Wildman know that I am using those injectors when I get my TS reburned and then it will be an injector upgrade? Or does it not work like that? I have access to the SD injectors for free. Well just gotta trade my stock ones.
Old Nov 10, 2011 | 12:55 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Idk about whats needed to install them, but i believe once you have them in all you need is the tune for split shots and your good to go
Old Nov 10, 2011 | 12:57 PM
79OldBone's Avatar
79OldBone
So if they do just bolt in... then it would be almost like going to stage 1's?
Old Nov 10, 2011 | 01:10 PM
Ford4Life7.3
Well ours are 90 cc's and the SD's i believe are 140 CC's. Someone who knows for sure will chime in. Ive talked to people whove done it, just cant remember the numbers.
Old Nov 10, 2011 | 02:02 PM
fordpride's Avatar
fordpride
SD injectors will go right in (with new orings) and you just need tunes for split shots.
OBS injectors or AA 90cc
SD injectors or
AB120cc
AD140cc
JamesHajek's Avatar
JamesHajek
If they are free, go for it. You need to buy a set of orings. You should always use new orings when you put injectors into your truck. You will want to have your chip burned for split shots. You really should keep your single shots in case these don't run like you want. The timing is different between the two because of the split shot vs single shot so it might run a little funny.
I'm telling you all this from experience. I ran AB's in my truck for about 2 weeks. Didn't like them one bit and bought some stage 1 injectors instead. And no, SD injectors are nothing like going to stage 1's. It's like half assed stage .75
Old Nov 10, 2011 | 02:05 PM
79OldBone's Avatar
79OldBone
BUT if you have the chip reburned for the split shots it should work fine shouldnt it? Or will it still run funny even with the proper tune to back it up?
Old Nov 10, 2011 | 02:25 PM
JamesHajek's Avatar
JamesHajek
Should run OK with the tunes. I had my chip burned for the AB's and still was never happy with them.
Old Nov 10, 2011 | 02:28 PM
79OldBone's Avatar
79OldBone
Please explain tho for the unhappiness? Was it doggy? or did it seam like it had no power?
Old Nov 10, 2011 | 03:10 PM
JamesHajek's Avatar
JamesHajek
There was a small HP increase, they smoked pretty bad, set a CEL at WOT every time, idled rough. Just not what I was looking for.
Old Nov 10, 2011 | 03:14 PM
79OldBone's Avatar
79OldBone
Interesting.... who did your tune?
Old Nov 10, 2011 | 03:39 PM
JamesHajek's Avatar
JamesHajek
Tony does my tuning... I have no complaints with his tunes on the 1's and I'm sure he did his best with the splits. Just wasn't what I wanted. Don't let me make your decision. If you can get them for free, go for it, but I'm not sure I would give up your singles just in case...
Old Nov 10, 2011 | 06:09 PM
bad12jr's Avatar
bad12jr
The splits aren't gonna run well unless you upgrade the hpop. A 15* will not keep up with the ad's. I have ad's in my truck. I put a 17* in but it was weak. I now have a t500 and its night and day. They are a little smoky if you just stomp it. These being designed for the tighter SD housing doesn't help. I got a whole motor cheap so I figured I'd try em. My mileage went up a hair but my other injectors had a lot of miles.
Just give the tuner a heads up. When I get the funds I'm going to a set of 250/200s so these are temporary.
Old Nov 10, 2011 | 06:18 PM
JamesHajek's Avatar
JamesHajek
That's another thing, my mileage dropped way off with the splits in my truck.
Old Nov 10, 2011 | 08:56 PM
bad12jr's Avatar
bad12jr
Everything I'd heard was worse mileage but so far so good
