4.9 ENGINE STUDDERING
Old Jun 1, 2010 | 03:21 AM
jr80coupe's Avatar
jr80coupe
Question 4.9 ENGINE STUDDERING
I HAVE A 95 4.9 INLINE SIX AND I HAVE A PROBLEM. WHEN EVER I TAKE OFF THE TRUCK STARTS TO STUDDER AND DOES NOT WANT TO ADVANCE, THE MOTOR STRUGGLES TO PICK UP SPEED. I WANT TO FIX MY TRUCK ASAP. THANKS GUYS.
Old Jun 1, 2010 | 04:49 AM
dustybumpers's Avatar
dustybumpers
clutch or auto?
Old Jun 1, 2010 | 09:59 AM
Rogue_Wulff's Avatar
Rogue_Wulff
From the vague description, it sounds like it could be anything from plugs/wires to a bad injector, vacuum leak, or even internal valve issues.
Help us help you. When was the last time the truck got a full tune up? Is this issue something that started suddenly, or did it get worse over time?
Old Jun 1, 2010 | 12:30 PM
jr80coupe's Avatar
jr80coupe
The truck is a 5 speed. I just got the truck like about 4 months ago and I have changed the spark plugs and the wires and the cap and rotor. I just put in a new clutch and a oil change and fuel filter. The truck has been doing that since I got it. A couple people told me that it could be that one of the cats might be bad or the fuel regulator is bad. I really like my truck and would like it to be running good but this is the only thing holding it back from running good.hopefully this info helps alittle more.
Old Jun 1, 2010 | 12:36 PM
Rogue_Wulff
I'd be checking for a vacuum hose that's broke or disconnected, or possibly a fuel injector that's bad or unplugged/broken wires.
Old Jun 1, 2010 | 12:50 PM
jr80coupe's Avatar
jr80coupe
I checked all the hoses and there all new. Do you think it could be a fuel problem or something like that? I'm new to the hole truck thing and inline 6 motors and I would like to know As much as I can about this motor since implanning of keeping my truck for a very long time. Is there any place were I can see how all the vaccum hoses are routed or were they plug into. Do you think it can be that a catalytic converter is bad?
Old Jun 1, 2010 | 03:01 PM
im2tall33's Avatar
im2tall33
it could also be the egr valve...or your ignition coil.. both easy fixes and should be done anyways... it takes about 20 min total..and you will get better fuel economy and throttle response..just my 2cents worth
Old Jun 1, 2010 | 03:03 PM
im2tall33's Avatar
im2tall33
how many miles are on the truck? it is possible the cat could be bad too.. if you live where you dont have to pass emmissions cut the thing out...
Rogue_Wulff
A bad cat will typically cause a major loss in power, but not a rough running condition.
One simple thing you can check is the plug wire order on the dist cap. If you simply replaced each wire one at a time, it could be wired wrong. Firing order on the I6 is 153624, and the cyl's are numbered 1-6 front to rear.
I'm not sure where to find a diagram or picture showing where all the vac hoses should be connected. I'm sure someone with a similar model truck could supply a few pictures, if needed.
Old Jun 1, 2010 | 03:06 PM
im2tall33's Avatar
im2tall33
this will help with the firing order
Old Jun 1, 2010 | 03:30 PM
jr80coupe's Avatar
jr80coupe
Thanks guys. I will check the firing order when I get home. Thanks again. I will reply with other q's if I have some . I'm new to the truck thing but I'm a die hard ford guy and proud owner of 4 mustangs, I'm looking to go with the 95 lightning look. I have 03 lightning wheels on it and 95 L seats. I will post a picture soon as soon as I get alittle more familiar with this forum. thanks for the help.
Old Jun 1, 2010 | 04:07 PM
jr80coupe's Avatar
jr80coupe
The truck has like 240k miles on it. I live in california and I need to have the cats on there. I want to have the truck running good with no worries of getting pulled over for no cats. This truck is going to be my daily driver because my other mustangs are all running without cats because there all fixed up.
Old Jun 1, 2010 | 04:29 PM
im2tall33's Avatar
im2tall33
well possibly that cat is really gumed up too.. check the firing order.. i would replace the cat if you can afford it and also try the egr valve and ignition coil.. you will be in good shape then..
Old Jun 1, 2010 | 04:41 PM
jr80coupe's Avatar
jr80coupe
Thanks im2tall33. I will check all three things and I will keep you guys posted. I will post the results later on today. Thanks.
Old Jun 1, 2010 | 05:14 PM
dustybumpers
check to see if the map sensor vacum line is still hooked up, it's above the heater on the firewall
