4.9 ENGINE STUDDERING
Old Jun 1, 2010 | 09:31 PM
jr80coupe's Avatar
jr80coupe
I checked the firing order and my dizzy shows my the #1 spark plug at the #5 spark plug. Do I need to move the dizzy so its at the #1 spark plug?
Old Jun 2, 2010 | 04:51 AM
dustybumpers's Avatar
dustybumpers
turn the dist to see if it will run better, set the timeing to 10*before, with the spout unhooked.
Old Jun 2, 2010 | 11:54 AM
jr80coupe's Avatar
jr80coupe
I think I figured out the problem. I was reading about the restrictor plate thread and I did one thing which it tells you to do which is plug the green hoes that goes to the EGR and I did and my truck ran a lot better. My dad is going to make me one and I'm going to try it when I get back from work. Hopefully this works. I have a good feeling that it is going to work but thanks guys for alll your help. I will keep you guys posted on what happens. Thanks.
Old Jun 2, 2010 | 03:40 PM
wolfy's Avatar
wolfy
you can always leave that green line plugged until you go to get your emission testing. Thats what i did!
https://www.ford-trucks.com/forums/1...ruising-5.html
Old Jun 2, 2010 | 03:56 PM
jr80coupe's Avatar
jr80coupe
So after I put that restrictor plate on I'm going to leave the green hose plugged and what about the little nipple were the green hose was connected? What do I do with that?
Shane Cummings
1997 - 2003 F150
260
Dec 31, 2024 09:01 PM
Sehandly
Mar 2, 2017 09:05 AM
SBFD8
Dec 4, 2016 08:40 PM
dumpguy
Dec 2, 2016 03:27 PM
goneinsixty
Feb 11, 2015 07:36 AM
