Sponsored by: Auxito
'01 Transmission Won't Shift
Old May 31, 2010 | 05:00 PM
brianfulwood's Avatar
brianfulwood
'01 F150 4WD w/ 5.4L, 118K miles. Problem started with a clunking sound shifting from 1st to 2nd. Now it will take off in 1st gear, but goes into neutral around 2000 rpm or 50 mph. It stays out of gear until the rpm drops under 1500, and then it will go back in gear. Give it some gas and it stays in gear until about 2000-2200 and it slips out again.
Fluid level is OK (changed filter and fluid last at 100K) and the color is nice and pink - not burnt. Any ideas?
Old May 31, 2010 | 08:51 PM
brianfulwood
No reverse gear, either, but I do have manual first. Switching OD on/off doesn't seem to affect it.
Old May 31, 2010 | 09:52 PM
93 mix 'n match's Avatar
93 mix 'n match
its toast.
Old May 31, 2010 | 10:18 PM
Supergordo's Avatar
Supergordo
The frictions in the direct drum are cooked and by the sounds of it the sun and/or planetary gears are damaged.
Old Jun 1, 2010 | 05:25 AM
brianfulwood
OK, thanks. That's what I was afraid of. I was hoping it would be something electronic.
I've rebuilt a few C4 and C6 trannies. How does this compare, and where's the best source for a rebuild kit and the hard parts?
4x4pwr
Mar 4, 2015 04:19 PM
bigbuick
1997 - 2003 F150
Nov 21, 2010 08:19 PM
bertha66
Aerostar
Aug 11, 2008 12:05 PM
Goober1979
27
Oct 30, 2006 12:05 PM
