overhead console fix question
Old May 31, 2010 | 02:37 PM
hdman6's Avatar
hdman6
Question overhead console fix question
Ok, I have my overhead console (2 door type). I have the display board sitting on my desk right here. So I have both chip 620 & 680 . They were completly off the board, laying in the plastic try. So can i reuse these chips? Also Ill i have is a reg soldering gun which when i saw how small this job is i had 2nd thoughts on doing it myself. Our nearby radio shach dosent have any soldering pencils so im out of luck. There is a local tv repair shop that does this type of stuff so i will have them do it. But can i give them the old chips that fell off along with a picture to show the placement? Im not sure if these can be reused... thanks Jeff
Old May 31, 2010 | 02:45 PM
DieselOrings's Avatar
DieselOrings
SPONSOR
Those are surface mount resistors, pretty stout little parts and have a better-than-great chance of being fine.
You don't want to try and re-solder with a regular soldering gun so your TV repair shop is your best bet.
__________________
Specializing in Viton® o-rings and leak repair kits for the 7.3L and 6.0L diesels
(970) 368-4455 aka guzzle
guzzle's Mods & Maintenance website
Old May 31, 2010 | 03:03 PM
zx250's Avatar
zx250
Of the next Riffraff East
Yeah, like Bob said, they are probably fine and like he also said, dont try with a big solder gun, you will just burn them up.
Old May 31, 2010 | 11:20 PM
SpringerPop's Avatar
SpringerPop
The two resistors are different values, and you need to let the repair shop know where each goes. They aren't interchangeable.
Here's where they go:
https://www.ford-trucks.com/user_gal...=99020&width=0
Pop
Old Jun 1, 2010 | 11:08 AM
rljett's Avatar
rljett
You'll find a lot of threads on this subject. I tried to solder mine back on but the fix would only last a few weeks. The issue is the resistors do not like high temp, so during normal operation, they get quite hot and the solder melts.
I ended up finding a thread that mentioned using non-surface mount resistors, which I picked up at Radio Shack. I soldered those in and have not had an issue for 6+ months.
You might want to skip reusing the surface mount type and get some of the other types for the repair, whether you do yourself or find a shop to do it.
Old Jun 1, 2010 | 05:40 PM
hdman6's Avatar
hdman6
Thumbs up
Just got backfrom getting the overhead board fixed. He resoldered the original ones in place. I had the picture for reference. I had him recheck the others and we added sone more solder to the others for insurance. I reassembled the unit and its like new. Even brighter than before. Maybe a few others were getting loose as well. When I asked him how much.. he said ah 2 bucks... I gave him 10. He made it look so easy but im sure i would have buggered it up. thanks to this forum i saved mayself big time again.. Jeff
Old Jun 1, 2010 | 05:45 PM
zx250's Avatar
zx250
Cool, thanks for following up and glad you got her fixed.
Old Jun 1, 2010 | 09:14 PM
ckelly83's Avatar
ckelly83
Hopefully, that's what is going on with my overhead console......it currently shows nothing. I'll try dismantling tommorow for a look-see. Thanks, guys
preppypyro
Nov 10, 2013 09:39 PM
wrxin
Aug 13, 2013 11:50 AM
c125bob
15
Jul 1, 2010 07:41 PM
jeffdoerr
Nov 17, 2008 10:25 AM
Bmoney
Electrical Systems/Wiring
Oct 22, 2005 04:53 PM
