two cats?
Old May 31, 2010 | 12:30 AM
mongo12's Avatar
mongo12
two cats?
i have my 93 f150 and i saw that there are two cats underneath. since i live in a smog area of reno, nv would it be legal to ditch one and install a free flowing one where the other is?
Old May 31, 2010 | 07:54 AM
TexasGuy001's Avatar
TexasGuy001
I would ditch them both and install a better one like Bassani, Magnaflow, or Catco.
Old May 31, 2010 | 08:30 AM
Conanski's Avatar
Conanski
You're going to have to check with the local authorities on that.
Old May 31, 2010 | 11:40 AM
TexasGuy001
I'm fairly sure the Calfornia is the only state where this would be an issue.
Old May 31, 2010 | 11:44 AM
LCAM-01XA's Avatar
LCAM-01XA
Nevada's getting pretty bad on that stuff tho, or so I hear - I suggest you go to your regular inspection station and ask the guys who will be inspecting your truck.
Old Jun 16, 2010 | 08:24 PM
Machman's Avatar
Machman
I replaced both of mine with a Walker 2 to 1 hi flow cat replacement pipe. It definately has a more pronounced exhaust note even with a new stock muffler. Sounds pretty good and still passes communist NJ emissions testing. Overall I used the 2 to 1 cat replacement with a gibson cat back single 3" swept side setup. Perfect fit and great quality.
Old Jun 17, 2010 | 04:00 AM
TexasGuy001
That sounds like a good setup.
Old Jun 17, 2010 | 01:56 PM
93MARKIII's Avatar
93MARKIII
a '93 is supposed to have two cats ?
mine has one, SISO that has a single upstream 0 sensor that is just south of the crossover pipe connection from the manifolds.....
Old Jun 18, 2010 | 05:27 AM
TexasGuy001
Most of our trucks came with 2 cats. Someone may have replaced yours at some point. When you say crossover pipe do you mean Y pipe?
A good high flow cat will do the same job as well as flow better and sound better.
Old Jun 18, 2010 | 09:27 AM
Bursch's Avatar
Bursch
I took both of mine out and put a straight pipe in. They were plugging up. Sounds great and more power. We dont have that waste of time and money inspection stuff here.
Old Jun 18, 2010 | 11:55 AM
TexasGuy001
The problem with doing that is that most states even if they dont' do sniffer test have a visual emissions inspection at the time of a safety inspection. Also, Doing that is illegal in all states, since its a federal law.
Old Jun 18, 2010 | 10:13 PM
BCHauler's Avatar
BCHauler
When I had my tranny redone, they insisted on hollowing out the first cat to reduce potential heat sources if it was clogged. When it came time to do emissions testing, the truck failed, so I replaced the 2nd cat with a magnaflow. Truck passed emissions and the setup looks reasonably stock (they checked to see if both were there with a mirror).
E150 4.9 1990
Sep 18, 2012 02:55 PM
Louisianaforddriver
Exhaust Systems
20
Aug 20, 2007 03:58 PM
RangerPilot
1983 - 2012 Ranger & B-Series
20
Oct 20, 2006 09:39 PM
homeslicedave
Exhaust Systems
Jan 27, 2004 07:35 PM
GSchretter
13
Feb 2, 2003 01:32 AM
