Sponsored by: Real Truck
caliper slide pin needs grease?
Old Jul 19, 2010 | 08:30 PM
brickie's Avatar
brickie
Is it the top or bottom bolt that has the slide pin.Thanks
Old Jul 19, 2010 | 08:36 PM
bubbasz1's Avatar
bubbasz1
The slide pins are in both top and bottom. They hold the caliper in position and let it float on the caliper mount(sorry no official name). I just did one rear brake this afternoon, chances are if it needs grease it needs to come apart and be cleaned. I had to get one pin out with the blue tip, just too much fun for a Monday.
Old Jul 19, 2010 | 08:55 PM
brickie's Avatar
brickie
I thought it was only one.Looks like I got a little extra work on my plate tonight.
Old Jul 19, 2010 | 11:19 PM
Waltdog's Avatar
Waltdog
of American machinists
Be sure to use the proper lube as well, normal grease is not for this job. You want something like this
http://www.permatex.com/products/Aut...per_Lube_1.htm
Old Jul 20, 2010 | 12:28 AM
DAVE67FD's Avatar
DAVE67FD
Hear's some info on the pins on removal. Ford sells a high temp teflon as well. Do a search on them as well for more info.
Welcome to guzzle's Powerslot/Hawk pads brake Maintenance Web Page
http://www.guzzle7pt3.com/cu.html
Old Jul 20, 2010 | 09:51 AM
JIMMYPBAILEY's Avatar
JIMMYPBAILEY
Talking caliper guide pins
both the top and bottom guide pins should move in and out with some effort. if they do not than you will need to maybe heat the caliper ancor plates where the pins are to remove them. ford does sell them in sets 1 set comes with 2 pins which will do 1 side. also keep in mind that there is a top and bottom pin and they are different from one another.
Old Jul 20, 2010 | 10:25 AM
brickie's Avatar
brickie
Thanks all,the deed is done.
jbucking
Oct 15, 2013 09:47 AM
MuttFTR
Sep 18, 2013 04:17 AM
A/Ox4
Aug 7, 2013 10:03 PM
PSNut
Oct 18, 2009 04:31 PM
bigrunnner
Jul 13, 2006 02:21 PM
