truck idle problems
Old May 30, 2010 | 06:51 PM
srutherford1's Avatar
srutherford1
truck idle problems
Hey guys I need help I have a 1982 ford econoline 3 100 it has the 300 I 6 the truck sat for like five years. I rebuilt the carb replaced the intake gasket rear main seal and fuel pump. The truck will only run if I hold the accelirator. I'm lost HELP
Old May 31, 2010 | 04:33 AM
Lazy K's Avatar
Lazy K
You might be better posting this on the page for earlier trucks. However make sure the ignition timing is correct, make sure that there are no vacuum leaks, check that the choke plate is working properly and check that the fuel level in the float chamber is correct.
Good luck.
Old Feb 3, 2024 | 07:53 AM
Greg1369's Avatar
Greg1369
4th Gear
There are lots of vacuum lines running around under the hood, and behind the passenger fender and even on the people side of the firewall behind the computer. In an old truck, i'd look carefully at the vacuum reservoir and the surrounding line. I believe on most, it's located in the passenger side inner wheel well.
Old Feb 3, 2024 | 06:24 PM
My4Fordtrucks's Avatar
My4Fordtrucks
This thread is 14 years old.
Brynjaminjones
13
Feb 5, 2019 03:48 AM
wyckedcombo17
Aug 15, 2014 06:25 AM
andrewscofield
29
Apr 22, 2013 01:55 PM
Steelpigs
Sep 3, 2011 08:02 PM
79BlueBetty
19
Sep 10, 2010 09:15 AM
