Hard Start, Needs some advice.
Old May 29, 2010 | 11:06 PM
quality1construction's Avatar
I have noticed gradually over the past 3 months my truck has not wanted to start unless its plugged in, yes even in the 95+ heat. I replaced all the glow plugs, and uvc harnesses, it tries much harder but still needs plugged in for about 15-20 minutes, any ideas? Both batteries are good, had tested, terminals have good connections. glow plug relay? bad injector(s)?? Thanks
Old May 29, 2010 | 11:16 PM
schlepprock250's Avatar
schlepprock250
Any smoke once it starts,if so what color?
Old May 29, 2010 | 11:33 PM
Trouble1263's Avatar
Trouble1263
Read this thread and see if this resembles your problem.https://www.ford-trucks.com/forums/9...fused-too.html
Old May 30, 2010 | 08:04 AM
I did not notice any smoke, but I will check later this morning. My problem does not really match the other thread. My truck will start fine if plugged in for 15-20 minutes, but won't start if its not even in the 95+ heat.
Old May 30, 2010 | 08:30 AM
1996pwrstrk's Avatar
1996pwrstrk
I had a starter slowly die on me so slow that I didn't notice it . It kept taking longer and longer to start till I finally realized the engine was turning over too slow. I pulled the starter and had it tested it was found to be bad ,replaced it and life was good again....
Old May 30, 2010 | 09:02 AM
Thanks for the reply, but the engine spins over fast. I replaced the started about a year ago as well.
Old May 30, 2010 | 08:33 PM
F350-6's Avatar
F350-6
How many miles on your injectors? How old is the IPR? How many miles on the engine oil and how often do you typically change it?
Old May 30, 2010 | 08:42 PM
twindad's Avatar
twindad
is the oil full, no offense but low oil will cause a hard start.
Old May 30, 2010 | 10:43 PM
I have no idea how many miles are on the injectors, truck had 275k when I bought it, now has 328k. yes the oil is full, I change it every 3500 miles.
Old May 30, 2010 | 10:51 PM
I have never changed the IPR, Is there anyway to test it? Thanks
Old May 31, 2010 | 06:53 AM
HD Rider's Avatar
HD Rider
Took me a while to find it. This thread sounds a lot like the issue you are having. https://www.ford-trucks.com/forums/9...ease-help.html
Old May 31, 2010 | 07:39 AM
F350-6's Avatar
F350-6
Not really without a scanner. You could get the kit from diesel o-rings and take it apart and clean it up to see if that helps, but there's no guarantee that is your problem.
