ATS housing installed now low boost.
i got the housing installed and took it for a test drive its still got good power but judgin by my boost gauge its loosing alot. 2k rpm its showing like 2-3 on the gauge and before it was 5-7. it drives the same and no sounds out of the ordinary. is it normal to loose that much with the housing?
Shouldn't lose any boost, but you may not have your compressor housing o-ring seated all the way, or have ripped it. I would take a look at that if it continues to seem low.
The mounting surface for the wastegate actuator on the ATS housing is less distance than the original housing. Your wastegate rod needs shortened; you are not making boost because your wastegate is probably not able to close and is hanging open. You shouldn't lose any boost with the ATS housing, if you are it's because of the actuator needing adjustment or what Clay said with the orings.
Glad you got it sorted it out somewhat. I adding spacers behind the actuator might put unneeded stress on the two studs, they are in single shear and there will be more leverage that way. They seem strong but I broke one off easily before. I like the idea of taking it back off and then spinning the actuator housing to tighten up the rod.
Reps for figuring it out.
Ken99F350dually7.3
16
10-25-2019 06:23 PM
tgreening
48
04-18-2016 02:37 PM
818rider
10-28-2015 09:20 AM
spdmpo
18
06-05-2009 01:33 PM
