E-Locker in the sand
Old May 29, 2010 | 08:41 PM
soundwave's Avatar
soundwave
I was wondering if I should engage the E-Locker in sand if I get stuck, or would that dig me in deeper? This is the first 4X4 Ive had with this feature and am still learning.
Thanks!
Old May 29, 2010 | 08:44 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
go for it. you'll either get stuck or not depending on the sand. 2 wheels pushing out back is better than only 1 wheel
best thing to do is air down your tires to about 20 psi so they balloon out and give you a bigger footprint
Old May 29, 2010 | 08:47 PM
soundwave's Avatar
soundwave
Do you think 20lbs would be good? When I last went out on the dunes, I had my Ranger FX4 I reduced the pressure down to about 15lbs and that worked good. But this is (obviously) a bigger truck and Ive got the 18in rim
Old May 29, 2010 | 08:48 PM
jstnromero's Avatar
jstnromero
Yep....Engage it! It will certainly help you out. All of my 4wd experience is in sand and a locker certainly makes a difference.
As tylus said....air down those tires. Just remember, the lower you go (pressure wise) the more careful that you must be when turning as you could pop a bead. Just watch it on the doughnuts!
Good luck and enjoy yourself.
Old May 30, 2010 | 12:46 AM
04XLTRUNNER's Avatar
04XLTRUNNER
the locker works great in the sand. but even with it unlocked I still get both rear tires to dig. it wouldnt hurt anything to lock it in.
Old May 30, 2010 | 07:27 AM
stephen.osborne1's Avatar
stephen.osborne1
try not to spin the tires from a stop... you'll have a tendancy to dig in and high center yourself... After you get some momentum, you can start to play with a rooster tail...
Old May 30, 2010 | 12:54 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
that is why I only recommend 20 psi. you'd probably be safe with 15 psi as well...but it is a heavy beast.
not to mention you have to drive to an air pump when the fun is over. 20 psi will be okay for low speeds (30 mph) to get to a gas station to air up
BSC71
2009 - 2014 F150
13
Jan 4, 2018 10:36 PM
Brian429
2015 - 2020 F150
15
Nov 29, 2016 05:48 PM
SkiSmuggs
6.7L Power Stroke Diesel
Nov 20, 2016 01:31 PM
Moundainner
Aug 14, 2016 09:27 AM
TractorM3
2015 - 2020 F150
Dec 13, 2015 04:29 PM
