coolant analyze
Old May 29, 2010 | 02:05 PM
sawduster1's Avatar
sawduster1
coolant analyze
I've got to r&r my egr cooler(bulletproof) and a few other things while I am in there and want to r&r the headbolts w/ ARP. I don't plan on pulling the heads, because the the egr cooler blew under warranty 10K ago and the headgaskets were supposidly good then. The oil cooler wasn't replaced and the exact same thing happened, just white smoke...no puking, no coolant in the oil, etc.
Although I'm pretty confident here, I thought I'd be safe and have the coolant analyzed for hydrocarbons before I busted knuckles.
Problem is I don't know where to have it done.
Old May 29, 2010 | 08:17 PM
roadrunner01's Avatar
roadrunner01
i use deere for coolant analyisis, i'm pretty sure a lab that tests oil also will test coolant
Old May 29, 2010 | 08:47 PM
sawduster1's Avatar
sawduster1
Do you mean through a local John Deere farm equipment dealer?
Old May 29, 2010 | 11:25 PM
roadrunner01
yes, but most labs do both.
also cat, cummins, international, detroit diesel, and many others offer this service.
hope this helps
Old May 30, 2010 | 12:20 AM
sawduster1's Avatar
sawduster1
hope this helps
Thanks greatly. Just what I needed...a direction to start looking in.
Old May 30, 2010 | 06:37 AM
bismic's Avatar
bismic
I haven't looked, but I bet most of these labs will do it ............
<TABLE style="WIDTH: 230pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=307 x:str><COLGROUP><COL style="WIDTH: 230pt; mso-width-source: userset; mso-width-alt: 10848" width=307><TBODY><TR style="HEIGHT: 13.6pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 230pt; HEIGHT: 13.6pt; BORDER-TOP: windowtext 0.5pt solid; BORDER-RIGHT: windowtext 0.5pt solid" class=xl24 height=18 width=307>OIL ANALYSIS</TD></TR><TR style="HEIGHT: 12.9pt; mso-height-source: userset" height=17><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 12.9pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 height=17 x:str="http://www.blackstone-labs.com/ ">http://www.blackstone-labs.com/ </TD></TR><TR style="HEIGHT: 30.1pt; mso-height-source: userset" height=40><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 30.1pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 height=40 x:str="http://www.dysonanalysis.com/ ">http://www.dysonanalysis.com/ </TD></TR><TR style="HEIGHT: 15.65pt" height=21><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 15.65pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 height=21>http://www.butler-machinery.com/services/product_support_oil.asp
</TD></TR><TR style="HEIGHT: 15.65pt" height=21><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 230pt; HEIGHT: 15.65pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=21 width=307>http://www.polarislabs1.com/</TD></TR><TR style="HEIGHT: 12.9pt" height=17><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 230pt; HEIGHT: 12.9pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl26 height=17 width=307>http://www.oaitesting.com/</TD></TR><TR style="HEIGHT: 12.9pt" height=17><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 12.9pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 height=17>http://www.avlab.com/</TD></TR><TR style="HEIGHT: 12.9pt" height=17><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; HEIGHT: 12.9pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl25 height=17>https://www.herguth.com/testing/prodprot.htm</TD></TR><TR style="HEIGHT: 16.5pt; mso-height-source: userset" height=22><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 230pt; HEIGHT: 16.5pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 0.5pt solid" class=xl27 height=22 width=307>http://www.mrtlaboratories.com/</TD></TR></TBODY></TABLE>
Old May 30, 2010 | 10:48 AM
sawduster1's Avatar
sawduster1
Many thanks bismic, you're a wealth of info, as usual.
