Wheres it from?
Old May 31, 2010 | 11:45 PM
  #46
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Best thing to do is set the intake dry, look at the gap you'll need to fill, pull it, then put a narrow bead just a tiny bit higher then the width (height/thickness) of the gap.
-Enjoy
fh : )_~
Old Jun 2, 2010 | 10:13 PM
  #47
FordNFishinLover's Avatar
FordNFishinLover
Thanks alot for the info yall.
Now Ctu, you mentioned checking the EGR valve while i had the chance. But what is this valve and how do i make sure its working correctly? Also is there anything else yall think i should check out while i got this stuff off??
Since im draining the anti freeze i figured id replace the lower radiator hose since its the only one thats not been replaced. Would it hurt or even do any good for me to run water through the radiator to try and clean it out or push any debri through it?
Thanks!
Old Jun 3, 2010 | 02:48 AM
  #48
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Flushing the cooling system is a good idea.
Be sure to get a lower radiator hose with a spring inside so that the waterpump cannot suck it flat and cause overheating.
Old Jun 3, 2010 | 09:37 PM
  #49
ctubutis's Avatar
ctubutis
Here's a pic:
This device is sandwiched between the carb & intake manifold , here is that
part removed but without the diaphragm attached:
To test it, get yourself a hand-held vacuum pump like this (auto parts store
might let you borrow one):
Apply vacuum to the diaphragm and make sure the valve opens & closes. I
suggest first leaning everything with carb cleaner or some such, there's likely a
carbon build-up inside.
An alternative to a vacuum pump is a vacuum source from a different, running
engine; all you're interested in doing is making sure the mechanism isn't stuck.
007bronco
May 5, 2014 04:03 PM
coleboy11
1983 - 2012 Ranger & B-Series
13
Mar 1, 2013 12:57 PM
minnesotafisherman
15
Jun 7, 2012 09:19 PM
OccidentalEx
17
Apr 9, 2012 01:14 PM
orange_x_crush
Sep 6, 2008 04:00 PM
