1978 - 1996 Big Bronco
How do i remove a stuck distributor
Old May 27, 2010 | 01:03 PM
torque head's Avatar
torque head
The distributor is stuck in the block and will not move. i have try trouching it ect. any other idea's???? the motor is on a stand.
Old May 28, 2010 | 04:53 AM
g_k50's Avatar
g_k50
Is this the 351? or the 302? It's a tight fit but it's not a press fit you should be able to lift it using hand tools. Take some pictures and let us see what you're doing. I would use some penetrating oil and try turning the distributor housing with a pipe wrench. Don't torque it like a main bearing cap bolt, wiggle it back and forth like a square peg stuck in a round hole.
Old May 28, 2010 | 05:27 AM
torque head
This is the 351, i've tried eveything you listed and then some. Can i get to it for the bottom side if i remove the oil pan?
Old May 28, 2010 | 05:13 PM
cOpE!'s Avatar
cOpE!
Try pulling up on it and rotating/twisting while you have a friend turn the crank
Old May 28, 2010 | 06:03 PM
torque head
Tried that too. the alum. is so brittle it just falling apart now. you just can't put alot of torque to it without it striping or breaking off. I think the bottom is the way to go.
Old May 28, 2010 | 08:31 PM
g_k50's Avatar
g_k50
You can't get to it from the bottom. Have you used penatrating oil? Have you taken out the retaning bolt and clamp? It's always something simple that's been overlooked.
Old May 28, 2010 | 08:32 PM
g_k50's Avatar
g_k50
Try a slide hammer.
Your avatar is not working.
Old May 28, 2010 | 09:01 PM
torque head
Not sure y the avatar not working, i can see it. Thanks i'll try something else.
Nope the bolts was out.
I'm going to try tonight to go at it from the bottom at least for S&G's
Old May 28, 2010 | 10:24 PM
g_k50's Avatar
g_k50
Try taking the camshaft out.
Old May 28, 2010 | 10:51 PM
torque head
Its OUT...... I torched until the AL was very soft and out it came....
Speedymaru
67
Aug 14, 2016 11:43 AM
Tim64
Nov 3, 2015 02:18 PM
79fordrat
Oct 21, 2012 04:13 PM
therealulysses
13
Jan 10, 2011 11:59 AM
scottddove
Aug 2, 2008 01:12 AM
