alright anyone show me how the tank on the frame rail is put on....
i go to install it today and i totaly draw a blank on how i took it off, well i took it off when the bed was on and now i have it off so that probably explains a lot. can u install and run without a bed without having the screw with the tank?
Usually the suction side is a larger size than return, so they should be impossible to mix up. If you have access, which you should with the bed off, dump a few gallons in, and blow a bit of air in, the suction side should bubble, but the return side should just vent out.
